Hi.
Anyone know how you can set global scale to 1 after scaling an object down?
I had to scale a model that I imported and now the smooth won't work while painting weights unless I use a huge brush.
I have tried setting neutral pose and freezing, but it won't affect the global scale. It stays 0,03 what ever I do, and I guess that's what matters to the weight brush.
Resetting global scale
Re: Resetting global scale
I remove your neutral pose first
Jho
Thanks a lot. I removed the neutral pose and reseted the scale. Scale seems to be 1 now. Smoothing still doesn't work though, so it must be something else.
