How do you determine which material a polygon uses?
For instance, say I have a grid with two clusters on it. There's 3 materials: The object material, and 1 material per cluster.
Now, I can tell which polygons are in each cluster by the elements property, but is there a easy way to determine which polygons should get the object material?
Materials & Polygons
Re: Materials & Polygons
Wouldn't that be the list of polygon ids minus the ids of the ones in the clusters with a local material?
TwinSnakes007
Yeah, that's what I came up with too. But, I was scared the performance would be horrible.EricTRocks wrote:Wouldn't that be the list of polygon ids minus the ids of the ones in the clusters with a local material?
EDIT: I'm gonna check to see how LuXSI does it.
EDIT2: LuXSI doesnt support multi-material either! Rats!
Just for reference, in 3Delight, multi-material is implemented as some kind of boolean switch - as multi-material isn't supported by Renderman standards, too. Implementation is a bit more sensitive than in MR, the best way is to put all polygons into clusters, if multi-material is used - but it works. Mix of master material and materials on cluster isn't good idea, anyway.TwinSnakes007 wrote:
TwinSnakes007
Well, another thing I was considering is just using ICE Materials instead of the clusters. Using ICE, it would be super easy and fast. I'd know how many materials are involved and there is a per-polygon MaterialID attribute to read. But, I havent played with that yet to see how its visualized. Clusters+Materials is visible using Shaded view. But, I'm not sure if ICE Materials is visible in Shaded view also.
Edit: I opened the MaterialID sample scene and ICE Materials are indeed visible in shaded view. So, looks like I'll be using ICE Materials.
