softimage on mac with crossover
clankill3r
Post by clankill3r » 11 May 2013, 09:48
Is this forum bugged?
Anyway, i trie to run softimage using crossover which is used to run windows game on a mac and it also support some programs.
The installation fails everytime.
Here is the log of 3 attempts, anyone a idea to get it futher?
2013/5/9:23:49:05 doekewartena Doekes-MacBook- === Setup started on Doekes-MacBook- by doekewartena ===
2013/5/9:23:49:05 doekewartena Doekes-MacBook- Launch
2013/5/9:23:49:05 doekewartena Doekes-MacBook- [Error: 1060] Service does not exist.
2013/5/9:23:49:05 doekewartena Doekes-MacBook- [Error: 6] Invalid handle.
2013/5/9:23:49:07 doekewartena Doekes-MacBook- PageOpen LaunchDialog
2013/5/9:23:49:10 doekewartena Doekes-MacBook- PageOpen LicenseDialog
2013/5/9:23:49:15 doekewartena Doekes-MacBook- PageOpen ProductInfoDialog
2013/5/9:23:49:31 doekewartena Doekes-MacBook- PageOpen ProductSelectionDialog2
2013/5/9:23:49:36 doekewartena Doekes-MacBook- PageOpen FullProgressDialog
2013/5/9:23:49:36 doekewartena Doekes-MacBook- Installing Microsoft Visual C++ 2008 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q /l C:\users\crossover\Temp\vcredist_x86_2008.log
2013/5/9:23:49:37 doekewartena Doekes-MacBook- Install Microsoft Visual C++ 2008 Redistributable (x86) Succeeded
2013/5/9:23:49:37 doekewartena Doekes-MacBook- Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): D:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\users\crossover\Temp\vcredist_x86_2005.log"" "
2013/5/9:23:49:39 doekewartena Doekes-MacBook- Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2013/5/9:23:49:39 doekewartena Doekes-MacBook- Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/5/9:23:49:42 doekewartena Doekes-MacBook- Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/5/9:23:49:42 doekewartena Doekes-MacBook- Installing .NET Framework Runtime 3.5 SP1: D:\3rdParty\NET\35SP1\wcu\dotNetFramework\dotNetFx35setup.exe /q /norestart
2013/5/10:00:00:59 doekewartena Doekes-MacBook- Install .NET Framework Runtime 3.5 SP1 Failed Failure is ignored, Result=1603
2013/5/10:00:00:59 doekewartena Doekes-MacBook- Install Autodesk Softimage 2013 32-bit Failed Installation aborted, Result=120
2013/5/10:00:01:00 doekewartena Doekes-MacBook- Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=2
2013/5/10:00:01:00 doekewartena Doekes-MacBook- Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
2013/5/10:00:01:00 doekewartena Doekes-MacBook- Rollback Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=2
2013/5/10:00:01:01 doekewartena Doekes-MacBook- PageOpen InstallCompleteDialog
2013/5/10:00:03:16 doekewartena Doekes-MacBook- [Error: 6] Invalid handle.
2013/5/10:00:03:16 doekewartena Doekes-MacBook- === Setup ended ===
2013/5/11:11:33:17 doekewartena Doekes-MacBook- === Setup started on Doekes-MacBook- by doekewartena ===
2013/5/11:11:33:17 doekewartena Doekes-MacBook- Launch
2013/5/11:11:33:20 doekewartena Doekes-MacBook- === Setup ended ===
2013/5/11:11:33:17 doekewartena Doekes-MacBook- [Error: 1060] Service does not exist.
2013/5/11:11:33:17 doekewartena Doekes-MacBook- [Error: 6] Invalid handle.
2013/5/11:11:33:20 doekewartena Doekes-MacBook- PageOpen LaunchDialog
2013/5/11:11:33:36 doekewartena Doekes-MacBook- PageOpen LicenseDialog
2013/5/11:11:33:36 doekewartena Doekes-MacBook- PageOpen ProductSelectionDialog2
2013/5/11:11:33:44 doekewartena Doekes-MacBook- PageOpen LicenseDialog
2013/5/11:11:33:44 doekewartena Doekes-MacBook- PageOpen LaunchDialog
2013/5/11:11:33:46 doekewartena Doekes-MacBook- PageOpen LicenseDialog
2013/5/11:11:33:52 doekewartena Doekes-MacBook- PageOpen ProductInfoDialog
2013/5/11:11:34:20 doekewartena Doekes-MacBook- PageOpen ProductSelectionDialog2
2013/5/11:11:34:30 doekewartena Doekes-MacBook- PageOpen FullProgressDialog
2013/5/11:11:34:30 doekewartena Doekes-MacBook- Installing .NET Framework Runtime 3.5 SP1: D:\3rdParty\NET\35SP1\wcu\dotNetFramework\dotNetFx35setup.exe /q /norestart
2013/5/11:11:35:24 doekewartena Doekes-MacBook- Install .NET Framework Runtime 3.5 SP1 Failed Failure is ignored, Result=1603
2013/5/11:11:35:24 doekewartena Doekes-MacBook- Install Autodesk Softimage 2013 32-bit Failed Installation aborted, Result=120
2013/5/11:11:35:24 doekewartena Doekes-MacBook- PageOpen InstallCompleteDialog
2013/5/11:11:36:33 doekewartena Doekes-MacBook- [Error: 6] Invalid handle.
2013/5/11:11:36:33 doekewartena Doekes-MacBook- === Setup ended ===
2013/5/11:11:39:04 doekewartena Doekes-MacBook- === Setup started on Doekes-MacBook- by doekewartena ===
2013/5/11:11:39:04 doekewartena Doekes-MacBook- Launch
2013/5/11:11:39:07 doekewartena Doekes-MacBook- === Setup ended ===
2013/5/11:11:39:05 doekewartena Doekes-MacBook- === Setup started on Doekes-MacBook- by doekewartena ===
2013/5/11:11:39:05 doekewartena Doekes-MacBook- Launch
2013/5/11:11:39:05 doekewartena Doekes-MacBook- [Error: 1060] Service does not exist.
2013/5/11:11:39:05 doekewartena Doekes-MacBook- [Error: 6] Invalid handle.
2013/5/11:11:39:07 doekewartena Doekes-MacBook- PageOpen LaunchDialog
2013/5/11:11:39:08 doekewartena Doekes-MacBook- PageOpen LicenseDialog
2013/5/11:11:39:14 doekewartena Doekes-MacBook- PageOpen ProductInfoDialog
2013/5/11:11:39:31 doekewartena Doekes-MacBook- PageOpen ProductSelectionDialog2
2013/5/11:11:40:04 doekewartena Doekes-MacBook- PageOpen FullProgressDialog
2013/5/11:11:40:04 doekewartena Doekes-MacBook- Installing .NET Framework Runtime 3.5 SP1: D:\3rdParty\NET\35SP1\wcu\dotNetFramework\dotNetFx35setup.exe /q /norestart
2013/5/11:11:43:20 doekewartena Doekes-MacBook- Install .NET Framework Runtime 3.5 SP1 Succeeded
2013/5/11:11:43:20 doekewartena Doekes-MacBook- Install Autodesk Softimage 2013 32-bit Failed Installation aborted, Result=120
2013/5/11:11:43:20 doekewartena Doekes-MacBook- Rollback .NET Framework Runtime 3.5 SP1 Failed Failure is ignored, Result=2
2013/5/11:11:43:21 doekewartena Doekes-MacBook- PageOpen InstallCompleteDialog
2013/5/11:11:44:14 doekewartena Doekes-MacBook- [Error: 6] Invalid handle.
2013/5/11:11:44:14 doekewartena Doekes-MacBook- === Setup ended ===
Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.Your message contains too few characters.
angus_davidson
Skype: ithacapellin
Re: softimage on mac with crossover
Post by angus_davidson » 11 May 2013, 13:34
Apart from purely a technical exercise there is no reason to try and run Softimage in cross over. Its a High Requirement Application. Put on bootcamp and run it natively in windows. You will be very happy with the result.
Technomancer at Digital Arts
Wits University
clankill3r
Post by clankill3r » 11 May 2013, 15:43
what bootcamp version do you use?
I putted windows 7 on it with a partition of 40gb but vista is taking up more then 30gb alone!
angus_davidson
Skype: ithacapellin
Post by angus_davidson » 11 May 2013, 18:28
I havent used vista. My windows 7 installs top up around 8GB. Which should leave plenty to install Softimage. It might be a bit tight if you install the whole autodesk media suite though.
Wits University
Post by Rork » 12 May 2013, 09:01
Just asking, but why using an OS that's over 6 years old and support for it is about to be stopped?
Also, the later Softimage versions might need something more recent that Vista.
Most of the people I know are running Windows apps via bootcamp, or within something like VMWare or Virtualbox.
clankill3r
Post by clankill3r » 12 May 2013, 09:37
I like windows 7.
I will look at VMWare and Virtualbox later.
Post by Rork » 12 May 2013, 09:46
you were talking about Vista...... That was released in jan. 2007 ;-)
clankill3r
Post by clankill3r » 12 May 2013, 09:52
windows 7 is from 2009.
Post by Rork » 12 May 2013, 10:06
Yes, I know, but you were talking about Vista..... That comes -before- Windows 7.
Or I have misunderstood your previous posts......
