selecting an area surrounded by an edge loop?
Post by Hirazi Blue » 09 May 2013, 13:41
I think this ultimately belongs in "Programming" as I haven't found a good solution yet and could probably use some pointers how to program this myself, but here goes: say I have a selected closed loop of edges surrounding a bunch of polygons, is there an easy way to select the polygon area surrounded by loop of edges? Something similar to "select adjacent polygons", but restricted to that specific area.
Re: selecting an area surrounded by an edge loop?
Post by rray » 09 May 2013, 13:56
The RcTools command "Fill" will do just that (if you want to cheat) ;)
(Although itself uses a "cheap" trick)
Post by Hirazi Blue » 09 May 2013, 14:04
Oops, you're right... :ymblushing:
I tend to forget about the awesomeness of the RCTools, just when I most need them!
Thanks for pointing this feature out to me again!
BTW: what trick did you employ?
Post by rray » 09 May 2013, 14:15
It disconnects the selected edges/polygons, then does a grow selection with 9000000 (or so) neighbors, and finally without shame deletes the disconnect op :ymblushing:
Seems to work without any side effects so credits for this mainly go to the programmers that did those individual commands.
