Can we not render 32 bit Radiance HDR ?
Caveman
Hi everyone is it not possible to render 32 bit Radiance HDR. The dropdown list contains only 8 bit, not even 16 bit
Re: Can we not render 32 bit Radiance HDR ?
I didn't check, but the output is probably 4x8 RGBE. iow, 32 bitsCaveman wrote:Hi everyone is it not possible to render 32 bit Radiance HDR. The dropdown list contains only 8 bit, not even 16 bit
Caveman
Probably I should have asked if 32 bits per channel rendering is possible with Radiance HDR.
Thanks.
Thanks.
.hdr files have no alpha channel. it's three 8 bit channels and a fourth 8 bit exponent channel. there is no point in a floating point .hdr file, use OpenExr instead. .hdr was created to avoid having floating point channels
Caveman
Thanks Luceric. I always render in open exr but recently I found that After Effects can output Radiance Sequence in Floating Point that's why I was asking.
