Edit: Rephrase what I meant
Netview within Submenu
Falam
Softimage can only open one Netview at a time which can be changed by displaying a different Netview by changing the HTML file. I don't want to change the current Netview that is displayed, which by default is the Softimage Navigation Netview. I want to add another under Netview within View > General > Netview as a second option within the submenu. On mostly everyones copy if Softimage when you go to View > General > Netview, a Softimage navigation Netview with videos is displayed. I want to add another Netview within the Submenu "NetView" that is on the top menu within Softimage giving me the option to choose between the regular Netview that everyone by default and another custom HTML page that I created.
Re: Netview within Submenu
Your question and explanation is a bit unclear. You can open mulitple netviews using the menu or hitting alt+5 multiple times.
Falam
I edited my original post, I hope it clears things upEricTRocks wrote:Your question and explanation is a bit unclear. You can open mulitple netviews using the menu or hitting alt+5 multiple times.
You would have to create 2 custom commands which each call the OpenNetView(URL) command, and add them to the View menu
This plugin does that.
function XSILoadPlugin( in_reg )
in_reg.Name = "NViews";
in_reg.RegisterMenu(siMenuMainApplicationViewsID, "Custom Netviews");
return true;
function CustomNetviews_Init( in_ctxt )
var oMenu = in_ctxt.source;
oMenu.AddCallbackItem( "Open Special netview no 1", "funct1");
oMenu.AddCallbackItem( "Open Special netview no 2", "funct2");
function funct1( in_ctxt )
OpenNetView("www.si-community.com");
function funct2( in_ctxt )
OpenNetView("www.xdugef.com");
}softimage resources section updated Sep 26th 2026
