Hi there
I'm trying to make a lawn, and in this scene a simple texture map will not do.
So I have a patch-of-grass Model made from ICE strands that looks nice and seems to render at a decent speed - next I want to rapidly replicate this in two directions at once... but I can't find an array replicate tool... I'm sure years ago (XSI 3.5 maybe?) I did something very similar to this with a tool that was found in Netview at the time...?
Does current XSI (I'm using 2013) have such a tool? Or is there a plugin someone could point me to that would do it quickly for me?
It would save a lot of time...
instance array replicator
Tekano
Re: instance array replicator
edit>duplicate>duplicate multiple ..? it has a transform panel option
snowctrl
- Skype: snowctrl
sorry, by 'array' I meant more than just a single dimension of duplication ie rather than just creating a line of Instances, I want to be able to create a grid of them
Am I missing something? I can't see a way of doing this with the Duplicate Multiple or Instantiate Multiple tools
3DSmax has been able to 'array duplicate' for a very long time...
jON
jON
You can do it in two steps. Duplicate N times to create the row. Then select the whole row and duplicate M times to create the columns.
Or instance with ICE using a grid pointcloud?
Chris_TC
Both are great options that I use often.xsisupport wrote:You can do it in two steps. Duplicate N times to create the row. Then select the whole row and duplicate M times to create the columns.
Of course doing it in ICE is infinitely preferrable if you want to be able to easily change placement and distribution later.
snowctrl
- Skype: snowctrl
Sorry for the late response, just got back to this after working on some other stuff
Got the ICE array method working thanks to this post:
http://xsisupport.com/2010/04/01/instan ... primitive/
It's a very nice solution
I love ICE (though I'm still a beginner at it)
Thanks for your help
