Uniform planar UV projection
bottleofram
Post by bottleofram » 01 May 2013, 10:03
Fairly simple question here.
Lets say i have a rectangular plane and i want to apply a planar UV projection to it. Easy enough: Property>Texture Projection>Planar XZ
This is the result:
Now, those faces are obviously stretched and i dont want that. I want texture support to be uniform. Like this:
Creating a subprojection with "Maintain Aspect Ratio" ticked on will give me the desired result but is there a way to do it without this extra step?
gaboraa
Re: Uniform planar UV projection
Post by gaboraa » 01 May 2013, 10:54
Have you tried "create new projection..." use best fit
bottleofram
Post by bottleofram » 01 May 2013, 11:44
gaboraa wrote:Have you tried "create new projection..." use best fit
Yeah, going with the texture wizard was the only clue i could find in the docs but no, it still fits it non-uniformly.
gaboraa
Post by gaboraa » 01 May 2013, 16:32
It works for me
gaboraa
Post by gaboraa » 01 May 2013, 18:50
BTW I used scaling on the mesh to make the square rectangle otherwise it won't work
