Hi
Well , I have a model with tree branch and the pointcloud that simulates leaves (instance Shape) on the branch, then I instantiated multiple copies of this model , and I can see that all of the instances have the leaves simulated on them , but at the time of rendering they dont appear , but the are clearly in the viewport , so if someone knows how to fix this, or if is just that it cant be done , I will really appreciate the help,
thank you in advance.
Problem: Instancing model with Pointclound?
alkimia
Re: Problem: Instancing model with Pointclound?
Well found the problem after and hour of testing stuff, it was because of two things first I had a intance_shape node plug into the shape port of the emitter and I changed it to a set_intance_shape node pluged into the execute port and that was the first thing , and second was that I moved my intance_master_model from the center of the world so the pointCloud wasnt in the center of the world and the leaves were getting lost. So I changed this two things and it got fix.
hope helps somebody if they have the same problem
