Post
by gaboraa » 25 Apr 2013, 09:05
Select your cut lines like you do when unwrapping and disconnect the edges and use the walk on mesh feature. Without disconnecting the cut lines you cannot use it. So we can say it is similar to UVLayout for both uses actual geometry to unwrap not the uv mesh.
