Can someone remind me the shortcut/mouse combinaison to adjust the 3 value in the same time in the tranform panel? I have kind of memory hole and can't fint it in the docs...
Shortcut to adjust the values in transform panel
sonictk
Re: Shortcut to adjust the values in transform panel
You can mark all 3 values in the keying panel and slide in the value box or hit F4 and use MMB-drag to adjust it while dragging in the viewport.NNois wrote:Hi,
AceMastermind
Editing Multiple Parameters in the Transform Panel
