Strands orientation flickering when scaling emitter geometry
Robert_XSI
Post by Robert_XSI » 17 Apr 2013, 09:57
Hi Softimage Friends! :)
I have an emitter for emitting particles strands (not simulated, only modelling mode).
I would like to scale the emitter geometry during the strand animation (not simulated), but when I scale the emitter
the strands (and the particle orientation), flickers, but only in a very few frames, and only a very few particles.
If I do not scale it, it is fine.
I tried almost all possibilities, combinations, without result...
Could someone help me a little in this, I could post a simple scene, if needed.
Any workarounds, tips are also welcome.
Thanks!!
It is quite urgent, my deadline is nearing...
Robert
Here is a simple scene (frame 3-4 flickers)
https://dl.dropboxusercontent.com/u/514 ... licker.zip
Tekano
Re: Strands orientation flickering when scaling emitter geometry
Post by Tekano » 17 Apr 2013, 12:05
Hello Robert_XSI
you ICE tree was overly complicated to demonstrate effect so I did not touch it. If I wanted to do what you described it would be done like the way I attached. no flickering
I think you are sampling the wrong thing to emit from and also not taking into account the global matrix of the emitter. anyway here is one solution attached
best regards
Robert_XSI
Post by Robert_XSI » 17 Apr 2013, 15:03
Tekano wrote:Hello Robert_XSI
best regards
Thanks Tekano, your scene seems to work.
I think my Align Particle to Surface node made the problems...
Robert
