Okay Just got tired of the issue of not being able to pin XSI to the start bar so I created a small application. XSI Bounce
Just copy it into the Appplication/bin folder. It shouldn't matter what version of XSI you are using.
All it does is check to see if XSI.bat is there and if it is run the batch file. It will then quit. On fast machines you probably won't even notice it opening.
That way you can easily pin something to the Start Bar / Task bar.
You can get it from http://db.tt/EG3p9Ihb
TODO. 1) Get a decent Icon, Currently just generic application Icon
2) Test to see if it works with network licensing
Kind regards
XSI Launcher
angus_davidson
- Skype: ithacapellin
XSI Launcher
Technomancer at Digital Arts
Wits University
Wits University
Re: XSI Launcher
angus_davidson
Re: XSI Launcher
Lucerics method works for the task bar. The launcher works for both start and the taskbar and allows you to just right click and select the pin option you want. There have always been workarounds, however the reason this discussion comes up again and again is because folks just want the right click option.Hirazi Blue wrote:I haven't checked this myself, but wouldn't the method described here by luceric be easier?
Wits University
Wits University
sonictk
Re: XSI Launcher
Oh boy oh boy a chance for me to pimp my tumblr:
http://cgreminders.tumblr.com/post/4192 ... ng-that-to
replace the target with your xsi.bat file. DONEBut what if you want to pin this to the taskbar? Because Win 7 does not allow pinning of batch scripts to the taskbar, what you have to do is make a shortcut lauching this batchscript through the command line, like so (place the following in your shortcut target):
%SystemRoot%\system32\cmd.exe /C “C:\whereever\the_batch_script_above.bat”
Then you can change the icon for that shortcut and pin it to the taskbar.
As a general rule, this is what you do whenever you want to pin a batch script to the taskbar.
angus_davidson
Re: XSI Launcher
thats useful to know. not just for SI either. Would work nicely for setting up batch files for renders too ;)
Wits University
Wits University
Re: XSI Launcher
The "pin" right-click option on the taskbar for running Softimage isn't going to work. By not working, I mean it's going to pin "xsi.exe" and not run xsi.bat. If you have a network setup and don't need any of the environment variables, you may not notice that it doesn't work because running xsi.exe directly works for you anyway.angus_davidson wrote:Lucerics method works for the task bar. The launcher works for both start and the taskbar and allows you to just right click and select the pin option you want. There have always been workarounds, however the reason this discussion comes up again and again is because folks just want the right click option.
angus_davidson
Re: XSI Launcher
Hi Lucericluceric wrote:The "pin" right-click option on the taskbar for running Softimage isn't going to work. By not working, I mean it's going to pin "xsi.exe" and not run xsi.bat. If you have a network setup and don't need any of the environment variables, you may not notice that it doesn't work because running xsi.exe directly works for you anyway.angus_davidson wrote:Lucerics method works for the task bar. The launcher works for both start and the taskbar and allows you to just right click and select the pin option you want. There have always been workarounds, however the reason this discussion comes up again and again is because folks just want the right click option.
I am not looking to pin the xsi.exe process. All its doing is allowing folks to be able to start xsi in another less annoying way
Wits University
Wits University
