Post
by Hirazi Blue » 14 Apr 2013, 10:38
Today I quickly wanted to install Softimage 2014 and its new license and I seem to have spotted a major bug, but I'd need some confirmation or an appropriate explanation before either blowing a fuse or give up on Softimage once and for all.
On my Windows 7 machine Softimage 2014 doesn't seem to kill its own process on exit. The XSI.exe process keeps visible in the Process Tab of the Windows Task Manager after exiting Softimage 2014 and SI2014 doesn't return its license to the License Manager, preventing usage of previous versions. Killing the process in the Task Manager would seem to be the only workaround.
I sure hope, I'm missing something, as this would be ridiculous (to say the least).
PS After killing the XSI.exe process the usage of previous versions is possible without a hitch.
Post
by xsisupport » 14 Apr 2013, 12:48
Maybe XSI.exe crashed on exit. Check if it is writing out a .dmp file in your Softimage User location.
// Steve Blair
// My Blogs:
Arnold |
Softimage
Post
by rray » 14 Apr 2013, 12:59
Do you happen to have any python plugin installed that imports windows libs? (f.ex. xpop, rcTools do that)
It crashes on exit when this is the case (Seems like a new bug)
Post
by xsisupport » 14 Apr 2013, 13:01
rray wrote:Do you happen to have any python plugin installed that imports windows libs? (f.ex. xpop, rcTools do that)
Yeah, I have rcTools, and python27.dll was at the top of the call stack!
// Steve Blair
// My Blogs:
Arnold |
Softimage
Post
by Hirazi Blue » 14 Apr 2013, 13:38
Softimage indeed writes a dump file (I should have thought of checking that first) and after removing RCTools and a few other addons wholesale (as just removing RCTools didn't do the trick), it seems to work as advertised. Thank you both.
@rray - Is there a workaround already? I would very much be able to keep on using the RCTools... And how would such a workaround apply to other addons/plugins?
Chris Chia
Post
by Chris Chia » 19 Apr 2013, 02:03
Just a side note:
Python 2.6.4 (this is the version we use in Softimage 2013)
pywin32 2.1.2 for Py2.6 (I used this: http://sourceforge.net/projects/pywin32/files/pywin32/Build%20212/pywin32-212.win-amd64-py2.6.exe/download)
Just point the PYTHONPATH env variable: to where your python 2.6.4 is installed (for example: C:\Python26)
This is just a workaround.
We will still investigate on why some python scripts won’t work in Py2.7 causing XSI process not to free up
iamVFX
Post
by iamVFX » 19 Apr 2013, 09:51
nice
Post
by Hirazi Blue » 19 Apr 2013, 10:29
Looking at that
bug report, the pywin32 people can't seem to reproduce it, so it will probably not be fixed anytime soon (it was reported in 217 and according to the changelog it wasn't fixed in 218). These kind of things sometimes make me wonder what happens during a Softimage beta. Reverting to internal Python 2.6 (and the corresponding pywin) before launch should have been easily doable, if only someone had noticed...
@Chris Chia - Thanks for specifying the necessary steps!
Maybe you could get someone to update
this download with the most recent files.
Post
by xsisupport » 19 Apr 2013, 10:51
I think that was a special python build for 2010 only, you couldn't get it anywhere else.
Now you can download Python and pywin from the usual places.
// Steve Blair
// My Blogs:
Arnold |
Softimage
Post
by Hirazi Blue » 19 Apr 2013, 10:56
You're right IIRC, but my point was, that having to revert to an external Python would be (even) easier if AD offered the necessary files in one simple rar/zip.
edit & PS: for those "on" Previous Versions with SI2013 (SP1) still installed: couldn't you just point PYTHONHOME to that specific "internal" Python?
Post
by rray » 19 Apr 2013, 12:35
Re: PS: Probably, that should be a full python installation inside the bin folder
Post
by rray » 19 Apr 2013, 16:13
PS: Welcome on board Chris!
Chris Chia
Post
by Chris Chia » 23 Apr 2013, 09:28
Hirazi Blue wrote:rray wrote:These kind of things sometimes make me wonder what happens during a Softimage beta. Reverting to internal Python 2.6 (and the corresponding pywin) before launch should have been easily doable, if only someone had noticed...
Hi Hirazi,
If you would like to contribute to Softimage beta testing,
do let me know
I could send you an invite, but it comes with a NDA (meaning you can't disclose any beta info to this forum)
Regards,
Chris
Post
by Hirazi Blue » 23 Apr 2013, 10:46
Thanks for the offer. I'll have to think about it.
My gripe wasn't with the beta list not doing a good job BTW, but with the sad fact there are always (sometimes seemingly small, but often quite fundamental) things the whole beta list seems to have missed (like for instance the infamous render time lag of a few versions back). Changing to a new Python version would seem to result in some additional testing I would think and the beta members would be able to test it with some common 3rd party plugins (like RCTools). And yes, I know it's easier criticizing the beta list "from the outside".
Post
by Hirazi Blue » 25 Apr 2013, 10:24
Just wanted to let you know, I just got word, the problem I reported earlier
now has officially been logged and has been designated as
SOFT-8889 Plugin conflict with Python 2.7 causes XSI Process not to free up
Here's hoping for a quick resolution (apart from the "workaround")
