Hello,
Im trying to figure out why, this whole mesh is displacing...
The displacement map is a .jpg done in photoshop with a grey of RGB : 128. Only the thin black lines should be displacing
I have tried RGB and greyscale .jpg..
Ryan
displacement issue
rpmaguire
- Skype: eyekeystudio
displacement issue
grahamef
Re: displacement issue
It's the middle gray that's causing that. You need to connect a Scalar Change Range between the Color to Scalar's out and the Displacement port so that the middle gray background gets mapped to 0 and the black to negative values.
BTW I really wouldn't use JPGs for this as the lossy compression can cause nasty artefacts. Use a lossless format like PNG.
rpmaguire
Thank you!
It worked fine..
It worked fine..
