Anyone knows a nice way to create a weight map based on component selection?
Tks!!
Component to Weightmap
spurv
- Skype: patodigital
Eu é que tou com cenas? Tu é que tás com cenas!
http://lickingtheice.tumblr.com
http://www.mariodomingos.com
Re: Component to Weightmap
Create a weight map on the object. Then select your points and open the weight editor. Use the tools in there to set the values on the selected points. Otherwise, you'll have to script it.
Select components
Select > Select adjacent points
Get > Property > Weightmap
or am I missing something?
Yeah it depends on whether you want a complete weight map for all points and the weights set to 1 based on your selection OR whether you just want a weight map that only covers the selected faces / points which is what Stephen showed how to do.
spurv
Eric's solution is more what I was looking for. I want to use the weight map with tim_SyflexJiggle. But Steve your tip is great never had thought about that.
Maybe there is a script already right?
