Elastic band rig
Announcements concerning cooperation, job offers or job requests
Zafar Iqbal
Elastic band rig
Post by Zafar Iqbal » 01 Apr 2013, 09:19
I'm looking for someone who can solve a problem for me - I need it done fast and hopefully someone can jump on this quick.
Following image explains the basic idea:
The band needs to be elastic so that I can stretch to whatever height/length.
The band needs to match the shape of whatever it is touching. The image shows a band wrapping a box and that's on the simpler end of the scale. The true challenge is to match the shape of something more complex - lets way an elephants back - an animated elephant on top of that.
The setup must be flexible enough to use in different scenarios.
Send me a PM along with few words about how you plan on solving this, how long it will take and your price.
I can provide more information in PM but by description pretty much sums it up.
I'm on SI 2013 and need this ASAP.
Thanks,
- Zafar Iqbal
Zafar Iqbal
Re: Elastic band rig
Post by Zafar Iqbal » 01 Apr 2013, 18:51
Found.
Thanks for the responses.
- Zafar Iqbal
Skype: ondraise
Post by Draise » 01 Apr 2013, 20:02
So what was the solution, mind I ask?
Zafar Iqbal
Post by Zafar Iqbal » 01 Apr 2013, 20:21
It's in the works and I'm told it will be ICE related.
- Zafar Iqbal
Post by Daniel Brassard » 02 Apr 2013, 14:16
Let me guess - ICE Syflex or Bullet physics implementation?
csaez
Skype: csaezmargotta
Post by csaez » 02 Apr 2013, 15:22
Or a simple raycast + manual offset controls as animation rig and a layer of simulation on top :)
Zafar Iqbal
Post by Zafar Iqbal » 02 Apr 2013, 23:20
Yes, pretty much something like that (and using Syflex). Not something I'd be able to come up with within a reasonable amount of time.
Helli
Post by Helli » 03 Apr 2013, 11:45
In the end Ice is used to calculate point positions with a basic raycast and interpolated arrays which then is used for a curve which is then simulated with syflex to achieve better collisions.
Real Mesh Collision Detection and Handling through Ice is still quite complex I guess and Syflex is the easier solution to handle this. Raycast didnt work for me for more or less a simple reason: in which direction u gonna cast the ray ?
