maybe someone here knows the answer?
I was trying to recreate the 'Range Mapper' node from Cinema 4D in Ice.
(i figured it would be really simple but it hasn't been yet)
A while ago i did a little kitche animation where all objects were animated without keyframes. (setting starttime and end time by hand typed)
(see pictures) That's the range mapper.
(the basic kitchen scene where all objects were animated)
(The Xpresso nodes I used for animating them)
(the node-settings (in yellow highlight) for animating each object)
in short let's say i want to move 1 cube somewhere at frame 51
i want to type eventualy:
* Start frame
* End Frame
* Start Position
* End position
just like in the range mapper node from Cinema 4D
Someone knows if this is possible at all with ICE?
