Hi everybody,
I'm rather new to Softimage, so i don't know if it's obvious or not...
In a non simulated ice tree, is it possible to get kine.global.pos ( or rotation, scale ) at a specific frame of an object ?
Precisely, i would like to emit one particle from a moving object at a specific frame.
For the moment, i copied manualy the vector position, but i prefer to automate the process.
any ideas ?
eben
ICE : get kine global position at a specific frame
eben
Re: ICE : get kine global position at a specific frame
You can't. However, you can create an ICE Tree that checks if you are at a particular frame and have the particles emitted only at that frame.
It's a little confusing in your post as you want to emit particles but in a non-simulated ICE Tree. Is this so or did the wording not come out right?
eben
thanks !
in fact, i don't use an emitter, but simply "add point" and i animate the point cloud by hand.
I tried to test frame and set data in an attribute, but in non simulated tree, it seems to not keep the value once go past the frame. I just wanted to avoid animate by hand, but it works in this way, so...
Any particular reason not wanting to simulate?
eben
well, just to avoid to cache several particles and an exercise as i feel more comfortable in a non simulated environment. It's not always possible.
I tried also with expression in a constant node, but i didn't find anything. It's strange to not have access to the motion curve at any frame or i miss something ?
Chris_TC
You'll have to use "greater than or equal to" if you're in a non-simulated tree. So that the Add Point is always evaluated when the frame has been reached.eben wrote:it seems to not keep the value once go past the frame. I just wanted to avoid animate by hand, but it works in this way, so...
Using the same nodes, a simulated tree instead would add a new point every frame.
eben
thanks for your answer,Chris_TC wrote:You'll have to use "greater than or equal to" if you're in a non-simulated tree. So that the Add Point is always evaluated when the frame has been reached.eben wrote:it seems to not keep the value once go past the frame. I just wanted to avoid animate by hand, but it works in this way, so...
it's ok for the "add point" but if i try to retrieve the position of an object at a specific frame it doesn't work whatever it's "equal" or "greater than or equal to".
in case of "equal", the position is only evaluated at the specific frame, but the value "doesn't stay" in the attribute after.
in case of "greater than or equal to" the position is evaluated each frame so it's useless.
is there any expression to do that ?
PS : sorry for my random english
Chris_TC
I had a quick look through the expression reference but couldn't find anything. Here's something that worked though:eben wrote:it's ok for the "add point" but if i try to retrieve the position of an object at a specific frame it doesn't work whatever it's "equal" or "greater than or equal to".
Create a custom parameter set on your point cloud. Add a custom parameter. Set a scripted operator on the parameter, for example:
Out.Value = Application.Dictionary.GetObject("sphere").posx.Source.Eval(11)
This evaluates the posx of object "sphere" at frame 11 and sets your custom parameter accordingly. The ICE tree can then access the custom parameter via a standard Get Data.
Would love to hear about an easier way though.
In the OM, you can use Primitive.Geometry or Primitive.GetGeometry2 to get the geo at a specific frame/time.
Getting geo from other frames is not really the ICE way methinks.
eben
Thanks for your answers.
I thougth there's an easy way too. I'll dig in custom parameters, i don't know how to use it for the moment...
