Old Room
Comments on finished work
Diurno
Old Room
Post by Diurno » 21 Mar 2013, 12:39
Finally, thanks to some really helpfull suggestion from many of you, i finished my still image. I'm happy with the result so i'll share it ^^
C&C welcome.
Skype: ondraise
Re: Old Room
Post by Draise » 21 Mar 2013, 17:16
Me gusta :)
flashgordy
Re: Old Room
Post by flashgordy » 25 Apr 2013, 09:43
models and textures looks ok, but light should be improved.
I think that you shoul raise up intensity and add more yellow (fire) color.
Light fallof also isn't good for me - generally in light emission place should be really bright
Diurno
Re: Old Room
Post by Diurno » 25 Apr 2013, 11:19
Yeah you're right, unfortunately it was to stressfull to rebalance things with MR. To get a speedy feedback with light setup, i had to work on a clay image, and on the clay the lights look much better, but i haven't enought patience to tweak the lights and wait for a 30min render with texture every little fix i make...
Maybe i'll work in it in the future, but ATM i'm working on a still with Maxwell Render (it's in the wip section if you wants to check the progress) ^^
flashgordy
Re: Old Room
Post by flashgordy » 25 Apr 2013, 12:59
You could use posproduction tricks, this is a normal thing in 3d. In stills Photoshop mainly, in animation after effects, combustion, fusion and other
I did a small presentation (use mask in "levels" little mix red and blue channel) - I did not mean to offend you, but only show what you can achieve in posproduction - it tooks me about 2 minutes
regards
Diurno
Re: Old Room
Post by Diurno » 25 Apr 2013, 15:35
flashgordy wrote:You could use posproduction tricks, this is a normal thing in 3d. In stills Photoshop mainly, in animation after effects, combustion, fusion and other
regards
i'm not offended at all, but for that still, the purpose was to work with procedural texture in Softimage, so i didn't mind a lot with postproduction. :D
Btw yes, the light should be a little more intense, but i doubt that a oil lamp covered with a frosty glass would project all that amount of light. Beside it would lose all the "dark" ambient that i would to accomplish.
