Best Video card for the best viewport perfomance
Nizar
Post by Nizar » 19 Mar 2013, 19:10
I know was debated before, but now there is new VGA released by Nvidia and AMD and only now I need to upgrade my card...
So, anyone has advice about a video card to buy? I'm oriented on AMD gaming card.
doca
Re: Best Video card for the best viewport perfomance
Post by doca » 20 Mar 2013, 01:28
Hi. As it is mentioned in some forums, nVidia is forcing you to get professional quadro cards by degrading some performances (from XSI user pov-degrading openGL performance). How they do that, I dont know, but I can tell you my experience few days before. I have tested nVidia gtx 680, nVidia gtx 570 and 4 of 5 years old nVidia gtx 285. I have them all, currently in my working machine 680, and in my secondary machines later two gtx-s. Even now, 285 is outperforming 570 and 680 in viewport performances. Not too much, about 3-5% in cinebench, but that is about 5 years old card. Maybe even more, cant remember. Also, seems to me that working in xsi is more comfortable with 285.
I can speak only about nVidia graphics, as I dont have ATI. Currently, it is very hard to find well balanced gaming card for work, and I am very unhappy with gtx680.
But, at the end, why dont we make one xsi test scene, to get results from various cards, and to find out what is the ultimative XSI graphic card, both professional and gaming cards.
Post by rray » 20 Mar 2013, 01:52
ImportModel("C:\\Program Files\\Autodesk\\Softimage 2013 SP1\\Data\\XSI_SAMPLES\\Models\\Characters\\XSI_Man_Armored.emdl", null, null, null, null, null, null);
SelectObj("XSI_Man_Armored.Body", null, true);
ApplyTopoOp("MeshLocalSubdivision", "XSI_Man_Armored.Body.poly[*]", 3, siPersistentOperation, null);
SetValue("XSI_Man_Armored.Body.polymsh.meshlocalsubdivisionop.subdivisionlevel", 3, null);
SetValue("Camera.camvis.refreshrate", true, null);
ActivateRaycastPolySelTool(null);
SetDisplayMode("Camera", "textured");
SelectAllUsingFilter("Polygon", siCheckComponentVisibility, null, null);
GTX 670 (Asus DirectCU2): (Really happy with the card although it at first crashed SI. Worked after patching a dll.)
15 fps unsubdivided (1 mil polygons) with all polygons selected (subcomponent highlighting which draws very slow in softimage)
60 fps unsubdivided without selection
2 fps subdivided (4 mil polygons) all polygons selected
45 fps subdivided, when all objects are unselected
GTX 460
10 fps unsubdivided, all polys selected
60 fps unsubdivided, no selection
1 fps subdivided, all polys selected
30 fps subdivided, no selection
*edit: sorry should have clarified - framerate is with with full model in view, and viewport orbiting, so the envelope doesn't have an influence
Reason: update
doca
Post by doca » 20 Mar 2013, 03:11
Thanks rray! Your scene is as script opens it, with only legs visible, isn't it? And only hit "play", just to be clear?
Can I ask, what dll you patched and why?
Gigabyte GTX 680/ intel i7-930
12.5 fps
23 fps
3.2 fps
8.5 fps
Gainward GTX 285/ intel i7-2600k
12.5 fps
20.5 fps
3.7 fps
9 fps
sonictk
Post by sonictk » 20 Mar 2013, 03:55
Since we're comparing our d**k sizes here :P Just wanted to pipe in and say that Quadro isn't always necessarily better...but I would stick with NVIDIA because of CUDA and PhysX...
Quadro k2000M (i7 3630 QM, 24 GB RAM)
~15 FPS (no subD, unselected)
~10 FPS (no subD, selected)
~ 0.2 FPS (subD lv 1, unselected)
~ 0.1 FPS (subD lv1, all selected) (actually much slower, but 0.1 is the lowest the readout will go :P)
Worth mentioning: my GTX 560Ti on my main rig (i5-2500k, 16 GB RAM) actually outperforms the Quadro by quite a bit (almost a factor of two), which I think is hilarious, all things considered.
However, that being said, I can actually paint with my Quadro in Mudbox at full texture resolution, on multiple 16bpp layers with zero/little slowdown, whereas on my GeForce, everything slows down to a crawl after a certain point and I am forced to merge my layers in order to get usable performance. Perhaps it's also on the part of the XSI viewport in dire need of some performance improvements as well...
I dunno, I was expecting like a MILLION FPS when I bought this thing, but alas. Also i should mention that swapping between subD levels took like an supremely-long amount of time as well, and switching beyond subD 2 for the man actually crashed XSI. :X
I should import one of my old environment scenes and have a HQV test of that. :D
Post by ActionArt » 20 Mar 2013, 04:09
I remember this cropping up on the the xsibase forum. There's one big question here:
Why is rray's 670 way faster than doca's 680?
That makes no sense. Are the top end cards hobbled more than low end cards? Is there something else wrong? Is there a setting that makes the difference? This is a mystery...
I remember in xsibase my 470 way outperformed a 480 at the time. Same issue.
mirkoj
Skype: mirko-jankovic
Post by mirkoj » 20 Mar 2013, 08:21
you have influence of cpu in this scene as well with all envelopes to be processed. there is older scene that more suits pure GPU performance.
actualy I think that was back on xsibased... here is script:
Application.CreatePrim("Cube", "MeshSurface", "", "")
Application.SetValue("cube.polymsh.geom.subdivu", 831, "")
Application.SetValue("cube.polymsh.geom.subdivv", 800, "")
Application.SetValue("cube.polymsh.geom.subdivbase", 800, "")
Application.SetValue("Camera.camvis.refreshrate", True, "")
Application.SetDisplayMode("Camera", "shaded")
Application.DeselectAll()
Application.SetValue("PlayControl.Out", 5000, "")
Application.GetPrim("Null", "", "", "")
Application.SelectObj("Camera_Root", "", "")
Application.CopyPaste("Camera_Root", "", "null", 1)
Application.SelectObj("null", "", "")
Application.SaveKey("null.kine.local.rotx,null.kine.local.roty,null.kine.local.rotz", 1, "", "", "", "", "")
Application.SetValue("PlayControl.Key", 5000, "")
Application.SetValue("PlayControl.Current", 5000, "")
Application.Rotate("", 0, 8000, 0, "siAbsolute", "siPivot", "siObj", "siY", "", "", "", "", "", "", "", 0, "")
Application.SaveKey("null.kine.local.rotx,null.kine.local.roty,null.kine.local.rotz", 5000, "", "", "", "", "")
Application.FirstFrame()
And results with 7970:
Shaded: 160 fps
Wire: 120 fps
With some older version of drivers I had up to 175 fps in shaded and with just a bit OC can easily push to 200 fps in shaded.
Problem with gtx580 was that once started play first it would stick at around 17 fps for 30-40sec and only after that it could up to 60-70 if I remember correctly. WOuld be great to see updated results with some of never cards as well.
Post by rray » 20 Mar 2013, 09:32
mircoj wrote:you have influence of cpu in this scene as well with all envelopes to be processed. there is older scene that more suits pure GPU performance.
doca wrote:Thanks rray! Your scene is as script opens it, with only legs visible, isn't it? And only hit "play", just to be clear? Can I ask, what dll you patched and why?
Sorry I meant orbiting because with play the envelope does have an influence. I didn't use the cube scene because I looked for something with a texture. I patched mentalray.dll, Softimage crashed on startup, before showing the viewports, without that patch.
To get back more on topic, can anybody test this with an ATI?
mirkoj
Post by mirkoj » 20 Mar 2013, 10:27
now it is more clear )
ati hd7970
orbiting with everything visible in view unselected: ~88 fps
geometry selected object mode: ~60 fps
geometry component mode: 8.6 fps
subdiv (once right?)
orbiting with everything visible in view unselected: ~82 fps
geometry selected object mode: ~30 fps
geometry component mode: 0.8 fps
body head and gun from geometry selected.
Nizar
Post by Nizar » 20 Mar 2013, 10:37
So, seems ATI 7970 wins these round. Actually the price seems nice, 350 € for a model with 3gb
A shame these card are not useful for gpu rendering.
mirkoj
Post by mirkoj » 20 Mar 2013, 10:57
yea shame that new Redshift renderer is still not supporting opencl.
When and hopefully it will once it will be no brainer to think what will be your next card for SI.
btw would be grat if someone with some firepro series card do this test as well. Still wondering if there would be some performance gain
with for example w7000. That one seems to have pretty nice price but would it be faster than 7970?
Post by origin » 20 Mar 2013, 12:08
I have selection lag with ati 7870...
Nizar
Post by Nizar » 20 Mar 2013, 12:20
origin wrote:I have selection lag with ati 7870...
Not a good news...
I don't use at all HQV, but how ATI will perform under HQV environment?
Post by ActionArt » 20 Mar 2013, 13:35
mirkoj wrote:yea shame that new Redshift renderer is still not supporting opencl.
I don't think it's too fair to expect that at this point. Developing for 1 platform would be hard enough and from what Luceric and others have said, opencl is a mess right now, way behind cuda. So until that gets straightened out, I wouldn't expect to see it.
Nizar
Post by Nizar » 20 Mar 2013, 13:38
yes but a quadro look like very too expensive to be honest...
Post by ActionArt » 20 Mar 2013, 14:55
Using rray's script in a GTX 470 I got these results:
GTX 470
18 fps unsubdivided, all polys selected
24 fps unsubdivided, no selection
6 fps subdivided, all polys selected
14 fps subdivided, no selection
Then a strange thing happened. After I subdivided and tested, I un-subdivided and it went from 24fpx to 45fps!
Results are very inconsistent for all modes. It's all over the board depending on what you do first.
