Softimage 2010 Rendering
bill
Post by bill » 30 Oct 2009, 22:12
Hi all :
What about this version Of softimage
I tried open more than 5 scene from my current project in softimage 2010 sp1 ,which was no render problem in xsi 6.5 ,but when i tried render it using softimage 2010 sp1 i have a different error messages (such as memory and fetal error ) and i can't see any result.
So what is this problem ?
And is this problem because my scenes builded in xsi 6.5 ?
Thank you
Bilal Moubarak
3D Team Leader
j3st3r
Re: Softimage 2010 Rendering
Post by j3st3r » 02 Nov 2009, 09:30
Lot of things changed since 6.5. Rerendering of scenes made in 6.5 is not a viable option. I suggest you to set up your rendering from the scratch. By the way, are you using 32 bit system? Adjusting MR memory at the optimisation panel of Render options may help resolving memory issues.
Post by Rork » 03 Nov 2009, 10:31
Also be sure not to have the ao cache set to 0, or MR will crash. It's a known issue in 2010.
And rendering a scene from an older version of any 3D app is risky at best.
bill
Post by bill » 16 Dec 2009, 20:23
Thank you Guys
Bilal Moubarak
3D Team Leader
