ICE Center Moves & Clusters
Falam
How come my object 'jumps' from it's center after applying and setting point position in ICE ? How do you convert a point cluster to a vector, I can't find a solution, with conversion nodes, math nodes ?
dwigfor
Re: ICE Center Moves & Clusters
Have you offset the SRT on your object (moved it from origin?). If so, try multiplying your pointposition by the object's kine.global via multiply vector by matrix.
Falam
self.pointposition > Multiple Vector by Matrix > ?
self.kine.global >
Set pointposition after multiple vector by matrix doesn't set the object self.kine.global back to it's original origin ?
self.kine.global >
Falam
Most likely the Build Array has no place in this tree. I couldn't set the multiple vector by matrix on the kine.global.pos, realizing setting it on the pointPosition is dumb
Can Geometry Queries node, do collision detection ?
dwigfor
Plug output of Multiply Vector by Matrix into Set Point Position -> ICE Tree.
How are you creating your points? Getting the cube's point positions -> Add Point? If so, you need to multiply the point positions by the cube's kine.global (the cube's SRT). That's what the Multiply Vector By Matrix does. Then you set the new positions.
Falam
dwigfor wrote:Plug output of Multiply Vector by Matrix into Set Point Position -> ICE Tree.
The object continues to jump from it's original center ?
Yeah, you're doing a double transform.
You're taking the local coords, converting them to global, and then stuffing that back into the local coords.
Suppose a point is at (1,0,0) relative to the center of an object.
But that object is located at (0,10,0) in global space.
You're moving that point to (1,10,0) in local space relative to the center of the object (and that center is already at (0,10,0)).
So your point ends up at (1,20,1).
Or something like that.
Falam
I get what you mean, with it doubling. Then how do I fix ?xsisupport wrote:Yeah, you're doing a double transform.
It depends on what you really want to do. I can't tell from the previous screenshots, sorry.
Falam
The object has it's local translation frozen. I want keep the object at it's new location, when I create a standard ICE tree the object 'jumps' from it's original position. I understand this is because it's on the global coordinate. I hope that was detailed enough ?xsisupport wrote:It depends on what you really want to do. I can't tell from the previous screenshots, sorry.
I don't repro that. Here's a little script. I create two cubes and translate them. On one I freeze the translation, and on the other I do a Set Neutral Pose. Then I put ICE trees on them with no jumping.
Application.CreatePrim("Cube", "MeshSurface", "", "")
Application.Translate("", 14, 9, 0, "siRelative", "siLocal", "siObj", "siXYZ", "", "", "", "", "", "", "", "", "", 0, "")
Application.ResetTransform("cube", "siCtr", "siTrn", "siXYZ")
Application.Translate("", -11, 10, 0, "siRelative", "siLocal", "siObj", "siXYZ", "", "", "", "", "", "", "", "", "", 0, "")
Application.SetNeutralPose("", "siSRT", "")
Application.ApplyOp("ICETree", "cube1", "siNode", "", "", 0)
Application.AddICECompoundNode("Set Point Position", "cube1.polymsh.ICETree")
Application.AddICECompoundNode("Get Point Position", "cube1.polymsh.ICETree")
Application.ConnectICENodes("cube1.polymsh.ICETree.Set_Point_Position.Position", "cube1.polymsh.ICETree.Get_Point_Position.Value")
Application.ConnectICENodes("cube1.polymsh.ICETree.port1", "cube1.polymsh.ICETree.Set_Point_Position.Execute")
Application.SelectObj("cube", "", True)
Application.ApplyOp("ICETree", "cube", "siNode", "", "", 0)
Application.AddICECompoundNode("Set Point Position", "cube.polymsh.ICETree")
Application.AddICECompoundNode("Get Point Position", "cube.polymsh.ICETree")
Application.ConnectICENodes("cube.polymsh.ICETree.Set_Point_Position.Position", "cube.polymsh.ICETree.Get_Point_Position.Value")
Application.ConnectICENodes("cube.polymsh.ICETree.port1", "cube.polymsh.ICETree.Set_Point_Position.Execute")
Falam
You were way off Blairxsisupport wrote:I don't repro that. Here's a little script. I create two cubes and translate them. On one I freeze the translation, and on the other I do a Set Neutral Pose. Then I put ICE trees on them with no jumping.
Application.CreatePrim("Cube", "MeshSurface", "", "") Application.Translate("", 14, 9, 0, "siRelative", "siLocal", "siObj", "siXYZ", "", "", "", "", "", "", "", "", "", 0, "") Application.ResetTransform("cube", "siCtr", "siTrn", "siXYZ") Application.CreatePrim("Cube", "MeshSurface", "", "") Application.Translate("", -11, 10, 0, "siRelative", "siLocal", "siObj", "siXYZ", "", "", "", "", "", "", "", "", "", 0, "") Application.SetNeutralPose("", "siSRT", "") Application.ApplyOp("ICETree", "cube1", "siNode", "", "", 0) Application.AddICECompoundNode("Set Point Position", "cube1.polymsh.ICETree") Application.AddICECompoundNode("Get Point Position", "cube1.polymsh.ICETree") Application.ConnectICENodes("cube1.polymsh.ICETree.Set_Point_Position.Position", "cube1.polymsh.ICETree.Get_Point_Position.Value") Application.ConnectICENodes("cube1.polymsh.ICETree.port1", "cube1.polymsh.ICETree.Set_Point_Position.Execute") Application.SelectObj("cube", "", True) Application.ApplyOp("ICETree", "cube", "siNode", "", "", 0) Application.AddICECompoundNode("Set Point Position", "cube.polymsh.ICETree") Application.AddICECompoundNode("Get Point Position", "cube.polymsh.ICETree") Application.ConnectICENodes("cube.polymsh.ICETree.Set_Point_Position.Position", "cube.polymsh.ICETree.Get_Point_Position.Value") Application.ConnectICENodes("cube.polymsh.ICETree.port1", "cube.polymsh.ICETree.Set_Point_Position.Execute")
The object 'jumps' from where I originally want it to be, what I meant by 'jump'
I don't see any jumping in Softimage 2013 SP1 when I run that script.
The objects don't move. Their centers don't move. Nothing moves.
Falam
I never said the script causes any object to jump. All the script does it get PointPosition and SetPointPosition for each cube, that is not my goal. My previous post demonstrates, I have an object with it's local coordinates frozen, after applying dwigfor ice tree the object continues to 'jump' from it's new frozen local coordinates, instead of staying where it should.xsisupport wrote:I don't see any jumping in Softimage 2013 SP1 when I run that script.
Why bother setting the point positions if you don't want anything to move?Falam wrote:I never said the script causes any object to jump. All the script does it get PointPosition and SetPointPosition for each cube, that is not my goal. My previous post demonstrates, I have an object with it's local coordinates frozen, after applying dwigfor ice tree the object continues to 'jump' from it's new frozen local coordinates, instead of staying where it should.xsisupport wrote:I don't see any jumping in Softimage 2013 SP1 when I run that script.
Falam
I want to ICE tree to work in the object local coordinates, rather in it's global. If I apply the ICE tree as demonstrated by dwigfor, the object as shown in the images moves from it's frozen translation. I want it to stay in it's frozen local transform, rather then move away.xsisupport wrote:Why bother setting the point positions if you don't want anything to move?Falam wrote:I never said the script causes any object to jump. All the script does it get PointPosition and SetPointPosition for each cube, that is not my goal. My previous post demonstrates, I have an object with it's local coordinates frozen, after applying dwigfor ice tree the object continues to 'jump' from it's new frozen local coordinates, instead of staying where it should.xsisupport wrote:I don't see any jumping in Softimage 2013 SP1 when I run that script.
The object center is placed on the object, in the images, when I apply the ICE tree dwigfor demonstrated the center stays in it's original position, but the object moves, I want to eliminate this when creating my compound.
