Randomized Color Map in ICE
ajhorvath
How would I get Randomized Color Map in ICE instead of Randomized color by Gradient?So I could have 6-7 different snoweflakes in my snowfall simulation.
Please Help!
Joseph
Please Help!
Joseph
clyder
Re: Randomized Color Map in ICE
You can make per particle integer attribute, make it random from 0 to 6 (if you have 7 different snowflake textures) and use that attribute in render tree with multi color switch.
Something like this:
ajhorvath
Thanks very much for the help.
I will do it.
Joseph
I will do it.
Joseph
ajhorvath
Just having one problem.How did you get the self.snowflake or an image into the Sat Data.
I have been rtying with no luck.
Please let me know
Joseph
Please let me know
Joseph
Double-click the "Set Data" node to open up its PPG and type "self.snowflake" in the text-box? It will probably stay red until you plug into some Execute port. ;)
ajhorvath
Still does not work,I just can't get my texture in there.
The trick is to create a custom attribute ("self.iceflake") in the "ICE Tree" and then to get the value of this custom attribute in the "Render Tree" using an "Attribute_Integer" node. Once you've set it in the "ICE Tree", your work there (in the "ICE Tree") is done and you can move on to the "Render Tree". In the "Render Tree" you plug your textures into a "Color_Multi_Switch" node to define all available options, using the "Attribute_Integer"-value as a switch between the different options...
While I am writing this (as I have no Softimage at hand at the moment), I hope this doesn't confuse the matter even more...
Feel free to ask more, if it does... ;)
ajhorvath
Thanks for the help.
How would I create the custom attribute ("self.iceflake") in the "ICE Tree?
I have created the material but I can't put it all together.
Joseph
Joseph
Plug the "Set Data" node, you've set to "self.iceflake" into an "Execute On Emit" port in your emitter node. You could also plug it directly into the "ICE Tree" itself, but I don't know, if that would result in the same effect...
ajhorvath
The problem is that I can't find the ("self.iceflake") to plug into the set data.
Where would I find it?
Joseph
Joseph
You simply type "self.iceflake" into the text field labeled "Reference". This should, after you've plugged the "Set Data" into some execute port create this custom attribute...
ajhorvath
Thanks for the help,but I am still having problems.My snowflakes still are not random and the values areall over .
Probably missing something really simple.
What do I do?
What do I do?
clyder
snowflake parameter is a scalar at your ICE tree and it should be integer. Get a integer constant node and plug it in set data node to switch it from scalar to integer. Then you can delete integer node and plug randomize by range node again. Also in render tree on attribute integer node where it says "Use Default Value" should be selected integer attribute from ICE tree.
ajhorvath
I got the scalar changed to integer but still the random snowflakes do not show up.
Any idea?
Any idea?
They should show up in a render region or a render preview as they are "created" at render time. Do they?
ajhorvath
Yes ,they are random at render time.
Thanks very much
Joseph
Thanks very much
Joseph
