gustavoeb wrote:By default Lagoa is setup as if 1 SI unit = 1 meter.
To solve this, multiply your gravity by 10.
The faster motion will probably lead you to use more substeps.
Hi
Gustav,
Hm, this is interesting. I completely forgot about the whole scale thing in softimage (always confusing...)
At the moment the scene was setup as if 1 SI unit = 0.1 meters (10 centimeters).
The effect I'm trying to achieve is a small lava explosion, so I'm using a cube (20 SI units) as a volume emitter.
What should the gravity be in this case?? Also, are there other parameters that would affect this and which?
Thank you very much for your time
