python tool not found in softimage
Falam
Post by Falam » 08 Mar 2013, 18:25
I have Python 2.6 set in my environment variable for windows. I have Python 2.7.3, PyQT and PyWin32-214 installed and followed the steps as directed on the authors web site for this tool. I can't see within File > Import ?
Re: python tool not found in softimage
Post by xsisupport » 08 Mar 2013, 21:25
1) Python 2.6 or 2.7.3?
2) You also need PyQtForSoftimage.
3) Does the system Python work in Softimage?
4) What error, if any, do you get when you install the addon? You can reload the plugin in the Plug-in Tree to repro any errors.
// Steve Blair
Falam
Post by Falam » 09 Mar 2013, 03:24
xsisupport wrote:1) Python 2.6 or 2.7.3?
The environment variable is set to 2.6. PyQT for Softimage is installed, didn't mention that :) The system python for Softimage works. The error I recieve is; which appears to be a script error.
#   File "<Script Block 2>", line 22, in <module>
#     import sip
# ImportError: No module named sip
{within MultiImporterQT.py}
Post by xsisupport » 09 Mar 2013, 11:58
That's the same error you get if you install the addon without PyQT and PyQTForSoftimage. So...
// Steve Blair
Falam
Post by Falam » 10 Mar 2013, 19:34
xsisupport wrote:That's the same error you get if you install the addon without PyQT and PyQTForSoftimage. So...
Post by xsisupport » 10 Mar 2013, 20:29
What I meant was: you still get the same error as if you didn't have those things installed, so that's where you need to start your investigation.
Why aren't those things found by the plugin?
// Steve Blair
Falam
Post by Falam » 10 Mar 2013, 21:13
xsisupport wrote:What I meant was: you still get the same error as if you didn't have those things installed, so that's where you need to start your investigation.
Originally, you sounded as though I didn't have the right extensions installed, therefore my replied followed.
Edit:
I have Python 2.6 set in my system environment path, and it works, because I have turned off to use Python with Softimage, GEAR no longer works, can't I use system python with GEAR (2.7) rather then Softimage python ?
Chris Chia
Post by Chris Chia » 23 Apr 2013, 09:33
#     import sip
Doesn't this mean that you don't have SIP module in your system python?
Try launching Python 2.6 in your terminal and import SIP to see if it recognises
