Hey Guys,
I am releasing the Scntoc Res Manager v1.0. This is a stand-alone app that I wrote in pyQt to open, view and modify .scntoc files.
The project is hosted on git, repo here:
https://github.com/alok1974/scntocResManager.git
For those of you using git and SSH, the repo can be cloned as:
git@github.com:alok1974/scntocResManager.git
The zip file version is available on the git page, also at:
http://bit.ly/WClRtl
Video explaining the application features:
https://vimeo.com/60980818
Soon, I will be packaging it all for a softimage plugin.
Please let me know how do you guys like it.
Scntoc Res Manager v 1.0 released
alok1974
Nothing will work unless you do - Maya Angelo
alok1974
Re: Scntoc Res Manager v 1.0 released
I have released Version 1.02 of the Scntoc Res Manager. There were a lot of improvement in the UI.
Here is the summary of ver 1.02 updates:
1. Ability to select and change resolution path of the multiple models in a single go.
2. A find and replace functionality in the resolution path change dialog.
2. A lot of bug fixes.
Also an addon for Softimage is released:
1. The exact same functionality as the stand alone application.
2. An open scene event to parse scntoc files before the scene is loaded.
3. A standalone GUI inside softimage as well so that any other scntoc file on disk can be opened and manipulated.
4. Open scene event can be enabled/disabled with a single command.
With this update I think most of the work needed for reference model resolution is concluded.
Here are the download links:
Scntoc Res Manager (StandAlone):
git:
zip:
http://bit.ly/XkguD0
Scntoc Res Manager Soft Addon:
http://bit.ly/15V6yQK
And here are the features video:
Standalone App:
https://vimeo.com/62579294
Soft Addon:
https://vimeo.com/62658588
Please drop me line if you have any suggestions, questions or bugs at:
alokdotgandhiatgmaildotcom
Here is what to expect in future:
Addtion of Passes and Render Settings manipulation from the Scntoc Manager.
git:
zip:
Standalone App:
Soft Addon:
Thanks Alok.
Nizar
Thanks for share, look very useful
kaizer_soze
Thank you for the tool and sharing !
