Batch render looks grainy...
Diurno
Post by Diurno » 16 Feb 2013, 13:04
Hi all, i've googled this issue and it seems i'm not the only one with this problem. Basically, the SAME image, if rendered with the user interface looks fine, but if i try to render it with the Batch Render by Prompt Command, turns out with some grainy noise on the darkest part....
My output it's set to Png sequence, and for work purpose i can't change it.
Sandy_S
Skype: bloogyct
Re: Batch render looks grainy...
Post by Sandy_S » 18 Feb 2013, 09:29
Sounds strange to me - the only thing I can think of is that you have some prefs set that the UI is accessing that the batch is not, are you running the batch on your machine, using the same login and running from the Softimage CMD?
S.
Diurno
Post by Diurno » 18 Feb 2013, 11:19
Sandy_S wrote:Sounds strange to me - the only thing I can think of is that you have some prefs set that the UI is accessing that the batch is not, are you running the batch on your machine, using the same login and running from the Softimage CMD?
S.
yea, the machine is the same from the same account by Softimage CMD. THe only reason i want to use the batch is that the crowd simulation render crash randomly, so with the batch i just have to restart the command, with the UI i've to close softimage, reopen it and so on.
I've searched for this grain issue, and a couple of people had this too, appears to be a gamma problem, cause i'm working with 2,2 by preferences. Unfortunately, they not found a solution...
Post by NNois » 19 Feb 2013, 01:51
i think png auto unpremultiply...
So try to check on/off premult in MR
you could also try the checkbox "apply display gamma correction" on your pass, but i doubt it...
you could also try to batchrender with the xsi command vs the xsibatch one
PS: id you render exr they can be batch converted to pngs in softimage fxtree via xsibatch if you need to ;-)
Diurno
Post by Diurno » 20 Feb 2013, 02:32
NNois wrote:i think png auto unpremultiply...
thanks for the suggestions, but:
-i can't check off premult, cause i need the alpha channel to composite the pass later
- apply display gamma correction i already on
- i don't remember right now if i already tried both xsi and xsibatch, i'll give a try tomorrow
Kzin
Post by Kzin » 21 Feb 2013, 09:54
grainy? what is grainy?
when you write user inferface, do you mean the render current pass feature in xsi or the render region?
because the render region is clamping the color values so it could be this. use the render current pass or preview feature on the machine where the rendering looks fine and compare with batch render.
Diurno
Post by Diurno » 21 Feb 2013, 11:14
Kzin wrote:grainy? what is grainy?
i mean with Render Current Pass.
