Disabling Lightmaps in a Material Override
MedAnimator_X
Post by MedAnimator_X » 07 Feb 2013, 17:16
So, I have a partition with my object in it. I was to do an incidence pass by overriding the surface of the material.
Here's the SSS material I'm overriding
Here's where I am thus far:
The partition has a material override and I plugged the incidence into the surface. My question is: How do I disable the lightmap it's writing? I'f im doing a quick/simple incidence pass I don't want it spitting out lightmaps while it does it. Typically I've just duplicated the shader/got rid of the lightmapwrite/threw it on the object's partition but I was wondering if there was a way to do it with override since it would save tons of time for me rather than duplicating and tweaking individual shaders for each object.
Re: Disabling Lightmaps in a Material Override
Post by Hirazi Blue » 08 Feb 2013, 11:17
An override won't work AFAIK, you could however assign your render pass its very own local Mental Ray and disable the creation of lightmaps in the local render options.
MedAnimator_X
Post by MedAnimator_X » 08 Feb 2013, 16:57
OH...... haha. Never thought of that, yup, that worked perfect and now my render is nice and fast! :) Thanks so much!
