I have a bottle and I want to apply a label with texture, but the background of this texture must be transparent. How can I make this?
Cheers,
Opacity by alpha or image as a mask
Leandro Oliveira
Re: Opacity by alpha or image as a mask
Sorry, I don't understand (but that could just by me, I hasten to add!
You want to place a label on a bottle, that much is clear, but what do you mean
by "the background of this texture must be transparent"?
Do you mean, that the unlabeled part should be transparent,
or do you mean something else?
Leandro Oliveira
Hi Hirazi,
I remembered a solution for my problem: use the channel Cuttout of the Archtectural shader. It works! I made a mask (a black and white image - Black = 100% transparent / White = 100% opaque) of my texture and used it. But, how can I make this using a default shader (like Phong)? There´s no opacity channel in the default shaders....
Cheers,
Cheers,
Simply plug the image into the transparency port of the shader?
You'll probably have to check the "invert" check box on the Transparency Tab...
Leandro Oliveira
Thanks, Hirazi. It worked!
But the transparency seems not to be 100% clear... I´ll make more tests and I´ll give you a return.
Thanks, again.
Thanks, again.
leandro,
have a look at the sprite node. The basic shaders have the annoying 'feature' to still have a specular on the transparent part driven by the alpha.
With the sprite node this is gone, and with multiple objects behind each other, rendering is much faster when using the sprite node.
There are some threads on stuff like this on XSIBase, just have a search ;)
And if I'm not mistaken, there was an old 'bottle label' tutorial on ed harriss his website.
Leandro Oliveira
Thank you, Rork.
I´ll study this shader. I´ve found the Ed Hariss´s tutorial about alpha channel. I´ll take a look on it, too.
Thanks.
Thanks.
