has anyone had this happening? When creating a compound you can't rearrange the exposed ports/parameters. Move up or down does nothing or it moves the port before the one selected.
Merge with new scene does not help.
2013 SP1.
ICE compounds - exposed port/parameters not moving up/down
druitre
csaez
- Skype: csaezmargotta
druitre
Re: ICE compounds - exposed port/parameters not moving up/down
You mean when a port is in a group it can't be moved?
[edit] Or when a port is under a port that is in a group? (Because that is my situation)
csaez
Both
Change the port order gets trickier when there're groups in the mix, I always end up setting them directly in the xsicompound file.
There's a bug where clicking the exposed ports doesn't work because there's an ice node underneath them, but this doesn't sound like that one.
druitre
How do you mean?csaez wrote: I always end up setting them directly in the xsicompound file.
csaez
You can edit the xsicompound file with any text editor and set the groups in the xml definition, it's a lot faster than using the GUI IMHO.
https://groups.google.com/d/msg/xsi_lis ... KFcIr5scIJ
druitre
Good to know, thanks. Would prefer a working GUI though. (For instance, being able to just drag 'n drop to rearrange order of ports). Something for feature request, I guess.
