Double Side Render with Arch Shader
Falam
Post by Falam » 30 Jan 2013, 15:08
I like, actually love the Arch Shader, too much so :) One thing that I've spent the last two days trying to solve, using the double sided shader which didn't work, I also played around with some of the matrix material nodes, which was more of 'playbox' experience then anything practical. I want to render as you see in my beautiful pipe, which has a eroded hole, the inside of the pipe without modelling it ?
caledonian_tartan
Re: Double Side Render with Arch Shader
Post by caledonian_tartan » 30 Jan 2013, 15:25
what if you further subdivide your model?
can you show a wireframe?
is there enough light in the scene or just a reflection map?
SI 2015 @ WIN7-64
Falam
Post by Falam » 30 Jan 2013, 22:36
caledonian_tartan wrote:what if you further subdivide your model?
There are enough lights, the object is reflecting the environment & map.
