We have 2 Licenses here.
One for SI only and
one for the Maya suite.
if i'm running SI and my colleague runs maya, everything's fine.
if i want to run Mudbox he has to quit Maya in order to set free the Suite License.
but then my softimage takes over the maya suite license too and i have to restart everything in order to set free the suite license.
i'm not shure if you understand the problem but it's VERY annoying.
ANY chance to force SI to ONLY use a CERTAIN License?
Prevent License Switch
caledonian_tartan
SI 2015 @ WIN7-64
Re: Prevent License Switch
Set up an options file.
That's how suite licenses work. Instead of your machine using two separate licenses, you use just one.
http://xsisupport.com/2012/07/24/softimage-license-cascading-sequence/
Note that if you start Softimage and check out a Softimage license, and then start a Suite app like Maya, then Softimage will switch over to the Suite license and free up that Softimage license it was using.
caledonian_tartan
caledonian_tartan
haven't had time to set up those files.
but if softimage can swap the license while running, it should be possible to create a script button to switch to a particular license?
SI 2015 @ WIN7-64
It's not possible.caledonian_tartan wrote:haven't had time to set up those files.
caledonian_tartan
ok. unfortunately i wasn't able to set up a license file.
because i don't want to completely exclude the Maya Suite License on my computer.
i want softimage to use the SI only license. and when i start Maya or mudbox, they use the MayaSuite License and SI should stick to it's own license...
tricky
tricky
SI 2015 @ WIN7-64
You need only to exclude the Softimage feature in the Maya ECSP license.
caledonian_tartan
absolutely.
i don't see how i can do this.
Excluding license usage
You can block access to specific licenses for a user, computer, group of users or computers, IP address, IP address range or by LM_PROJECT
variable association (computer names and user names are case sensitive).
Any users, hosts or IP addresses not explicitly excluded will continue to have access to these licenses.
EXCLUDE [productfeature] [type] [name]
i get something like this: (need to check the license name with our Admin)
EXCLUDE 48800MCE_2013_0F USER meMyself
so i can exclude the Maya Suite from my user account, but what i want is what you suggest. to exclude the maya license from my user accounts softimage.
SI 2015 @ WIN7-64
I guess Suite licenses no longer have product-specific features. I haven't seen an actual license for awhile.
Maybe you should EXCLUDE yourself from the Suite license and use a separate user account to run Mudbox.
