delete point from point cloud
clankill3r
Post by clankill3r » 27 Jan 2013, 21:24
I try to delete every point from a pointcloud that has a odd id.
Why do i get a error about a reference?
TwinSnakes007
Re: delete point from point cloud
Post by TwinSnakes007 » 27 Jan 2013, 21:31
Replace the "pointcloud.ID" node with a "Get Point ID" node.
Tekano
Post by Tekano » 27 Jan 2013, 21:36
almost there Clankiller, just disconnect the In name on the delete point, you are already filtering that set of points by modulo you do not need the name as well
Post by xsisupport » 28 Jan 2013, 11:30
Also, the In Name on Delete Point is for the name of a point cloud (not the name of PointCloud.ID).
// Steve Blair
clankill3r
Post by clankill3r » 29 Jan 2013, 16:30
thanks guys, got it working.
I also deleted the if node.
clankill3r
Post by clankill3r » 29 Jan 2013, 19:26
one more,
how can i remove points that match a certain id?
nixx
Post by nixx » 29 Jan 2013, 20:18
clankill3r wrote:one more,
What you have now gives you an array of results for the specific point id compared against every one of the array members. That's why the output is an array of booleans.
Use "Find in Array" instead of the "equal to" comparison operator. That way, if the point id is "found in the array", the node will return "true" -> point will be deleted.
I 'm child, and man, and child again; the boy never gets older.
my Vimeo
angelous4x
Post by angelous4x » 29 Jan 2013, 20:35
one other thing is just use the filter particle ID, it looks for the ID you type in. then get a string to array node, and paste all the particles you want to delete and there you go.
clankill3r
Post by clankill3r » 30 Jan 2013, 11:39
thanks
