Windows Key in Softimage
Falam
I realized that there is one keyboard command that is not in Softimage Keyboard mapping, that is the Windows Key. If the Windows Key could be part of Softimage Key Mapping it would open up a whole new keyboard short-cut world
I don't know if this has been mentioned before, or if I'm the first
It would be beneficial, maybe only to me, I dunno
gaboraa
Re: Windows Key in Softimage
I think the whole concept of key assignment has aged like many other features have been. It should be way efficient if the developers make something like Maya and cinema 4D. For example C4D allows assigning any key to any command. In this way many possibilities would be opened for the users.
I have a big autohotkey script running for everything that's so not quite configurable in Windows.
You could map things like Win+mousewheel up to frame forward, win+mousewheel down to go a frame backwards. etc
Falam
You can't map internal Softimage commands with AHK.rray wrote:I have a big autohotkey script running for everything that's so not quite configurable in Windows.
Not directly no, I meant using obscure keyboard combos you woudn't otherwise map like ctrl+alt+shift+pos1.. pretty useful especially the mousewheel to scrub the timeline
Falam
I could assign the Windows key to a Softimage add-on using AHK, if so, very interesting, I have AHK installed, how would this be setup ? (It is a nice tool to have, I know you agree RRay)rray wrote:Not directly no, I meant using obscure keyboard combos you woudn't otherwise map like ctrl+alt+shift+pos1.. pretty useful especially the mousewheel to scrub the timeline
Especially using a mouse where you can switch off the wheel's mechanical snapping ))
I have startup.ahk file with everything in it in myDocuments folder and put a link to it in Windows Autostart, should be all that's needed. Inside the script, write something like
#q::Send !+{F9}
which sends ALT+Shift+F9 when Win+q is pressed. There's some syntax too which makes it active only in Softimage, but I don't remember this right now.
docs: http://www.autohotkey.com/docs/
#q::Send !+{F9}
Falam
If you can remember, I would appreciate it. If I hunt down 'active commands for Softimage" within the AHK docs I won't find, anythingrray wrote:Especially using a mouse where you can switch off the wheel's mechanical snapping ))
#q::Send !+{F9}
If you take a few seconds to look at the AutoHotKey FAQ, you'll find something that looks very much like the answer.
It took me 10 seconds to find it. I spent longer typing this message
Falam
I'll look againxsisupport wrote:If you take a few seconds to look at the AutoHotKey FAQ, you'll find something that looks very much like the answer.
just remebered ;) .. top of script write
bottom:#NoEnv
#MaxHotkeysPerInterval 5000
#SingleInstance force
SetTitleMatchMode 2
SetBatchLines -1
SendMode Input ; Recommended for new scripts due to its superior speed and reliability.
SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory.
and two scripts to move the timeline slider without logging...#IfWinActive, Softimage
^WheelUp::Send !+{Right}
^WheelDown::Send !+{Left}
Falam
Thanks, plans became messed up <sigh>rray wrote:just remebered ;) .. top of script writebottom:#NoEnv
SetTitleMatchMode 2
SetBatchLines -1
SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory.and two scripts to move the timeline slider without logging...#IfWinActive, Softimage
