I didn't think it such a big fuss, but it seems to be. I want to deform a curve by an object. Actually the curve is supposed to glide over an object. But I can't get it to work. Get point position doesn't work on a curve. Why NOT! So I can't raycast anything or get a closest location. What am I doing wrong? Is there a workaround?
Pancho
Deform curve by ICE
Re: Deform curve by ICE
Strands are deformed by objects so it might be possible.
mattmos
Can you use the deform/shrinkwrap option rather than ICE?
csaez
- Skype: csaezmargotta
PointPosition works fine with curves.
The lines you see in the viewport are produced by an interpolation between the points (just like subd on polymeshes), so if you need a more precise control over the shape of the curve just add more points/resolution (create/curve/fit on curve)
