Exporting UV Values
TwinSnakes007
Exporting UV Values
Post by TwinSnakes007 » 01 Jan 2013, 02:58
I need some help with this part. Getting this data out of Softimage has been a challenge for me.
For a given PolygonMesh, how do you export the UV values?
face
Re: Exporting UV Values
Post by face » 01 Jan 2013, 13:59
Use the CGeometryAccessor.
There are some samples in the SDK.
face
csaez
Skype: csaezmargotta
Post by csaez » 01 Jan 2013, 14:20
This only works in a very simple scenario, if it's not a complete cluster you should match the indices with the geometry :)
oObj = Application.Selection(0)
for oCls in oObj.ActivePrimitive.Geometry.Clusters:
	for oProp in oCls.Properties:
		if oProp.Type != "uvspace":
			continue
		Application.LogMessage(oProp.FullName)
		Application.LogMessage(oProp.Elements.Array)
TwinSnakes007
Post by TwinSnakes007 » 01 Jan 2013, 16:19
Thanks guys...that worked.
