RenderTree Shader Values
TwinSnakes007
Post by TwinSnakes007 » 28 Dec 2012, 21:33
Is there anyway to read the values of a RenderTree shader? For instance, the Fractal_Scalar & Particle_Density nodes?
SI already has a mechanism for defining 3D volume data. Dont wanna have to recreate the wheel if I dont have to.
Re: RenderTree Shader Values
Post by rray » 29 Dec 2012, 01:44
TwinSnakes007 wrote:Is there anyway to read the values of a RenderTree shader?
From where?
TwinSnakes007
Post by TwinSnakes007 » 29 Dec 2012, 01:45
I dunno....just hoping there was a way via the SDK?
Like, I'm trying to support 3D volume data (point density). SI already has some shader nodes that help define that dataset. So, was just wondering is there anyway to read them or is it all on the MentalRay side?
Post by rray » 29 Dec 2012, 01:54
They're all in DLLs I assume so probably with some (or a lot of?) effort you could trick them into thinking you're being mental ray (Pass them a fake state struct etc..).
This would be a hack though, I don't think there's a supported way of talking to shaders.
Or did you mean, the shader settings?
TwinSnakes007
Post by TwinSnakes007 » 29 Dec 2012, 05:37
rray wrote:Or did you mean, the shader settings?
Nope, I mean the calculated particle density values from a typical render tree setup for volume particles.
face
Post by face » 29 Dec 2012, 08:43
Calculated output values are calculated in the renderer so it shouldn´t give a simple way to read they...
The problem is also that the output values are rgba color values.
face
