Stretchy IK in ICE and my Global_SRT cntrl
missingkey
Post by missingkey » 20 Dec 2012, 00:16
Hey Guys, New to both the forum and Softimage, I had a few questions I was hoping an experienced SI rigger could help me out with.
In Maya, I achieve proper scaling of my stretchy joints when the SRT is scaled by using a second chain in which I measure the distances needed - instead of having constant distances. This works really well, and prevents having to pipe any of the Global SRT's channel into any part of the rig.
I've essentially duplicated this maya node graph into SI ice nodes, but of course, I'm dealing with joint length, opposed to joint scale. and measuring those distances seem to have the desired effect I'm looking for when checking joint lengths, but It seems I'm still getting some double transforms/scaling issues. I've played around with the scaling options on the joints themselves (inherit scaling from parent...?) but I'm not getting the desired effect.
I'm sure it's simple, but could someone point me in the right direction please?
Best!
missingkey
Re: Stretchy IK in ICE and my Global_SRT cntrl
Post by missingkey » 20 Dec 2012, 03:44
So i've attempted to recreate the ICE tree on my bone's scaleX as opposed to length, But I'm running into issues trying to set data on the bone's scaleX at the end of the tree. This seems strange to me because I'm not getting the data for said bone's scaleX at any point in the tree. Cannot I not set local transforms with ice?
I suppose I could just write the expression on the joint's themselves and bypass Ice all together. Any suggestions for global scale and stretchy joints?
Best!
Post by EricTRocks » 20 Dec 2012, 04:18
If you're calculating values with the bone length and then scaling that same object you have to take the bone length multiplied by the scale to get an accurate distance. I would not recommend scaling the joints along the length if you can avoid it. I think it also depends where you are calculating the Maths as well. If you have the ICE Tree on the bone object then you're in a world of hurt having to do your calculations and consider that scaling with scale the local space in which the calculations are done. I'd recommend putting the ICE Tree on a node that doesn't receive any transforms that way you have a stable and non-varying space to calculate in.
Eric Thivierge
csaez
Skype: csaezmargotta
Post by csaez » 20 Dec 2012, 04:22
You can only set global transforms via ICE :)
Post by EricTRocks » 20 Dec 2012, 04:28
csaez wrote:You can only set global transforms via ICE :)
^ Yeah that too! :P
Eric Thivierge
mattmos
Post by mattmos » 20 Dec 2012, 09:13
I'd say you're a brave man for trying to rig in ICE, as the kinematics section has never been properly documented or exposed, with suitable examples, and leads to issues troubleshooting a non-traditional rig when you go back to it months later.
I'd say go with your second suggestion, set the expressions on the local kinematics using the traditional route, though I usually always include a mult with the global_srt, to ensure the scaling works when scaling the model. If you scale the length of the bone, you can run into issues with unwanted child scaling.
missingkey
Post by missingkey » 20 Dec 2012, 20:45
Hey Guys thanks for the help. Am I right that you also have to set the entire global matrix? instead of just say global scale? that makes things slightly more interesting.
The Ice tree is located on a dummy null right inside the model, outside of the global_SRT cntrl. I'd like to avoid having to pipe the Global_SRT's scale into any part of the Ice tree, But It seems that by using joint length as opposed to scale, it's unavoidable.
I'm not necessarily rigging entirely in Ice, but more just using it for connections/expressions. I think I will probably just end up writing the expression on the joints themselves. If I do it on scale, I can just do it like I do in Maya. With Joint length, I fear I'll have to incorporate the Global_SRT scale directly into the expression, instead of continually measuring the distances involved - and bypassing the SRT scale - How I'd prefer. I'm not skinning directly to the joints, but rather nulls in a bendy setup riding along the FK IK blend nulls.
Post by EricTRocks » 20 Dec 2012, 22:22
Yes you have to set the entire Matrix.
Can you just measure the distance between the bones using the global point position of bone01 to bone02? This removed the need to use the length param other than setting it.
Eric Thivierge
missingkey
Post by missingkey » 20 Dec 2012, 23:51
I thought that's was what I was doing, but maybe not. I don't have the scene in front of me, but later I will post a screenshot of my ice tree.
I'm using the distance between node to determine the distances of a separate null chain to use as the new distances for the joint length after scaling the SRT cntrl.
Perhaps I'm not using the distance between node correctly. Just connect the kine.global.pos of the bone01/bone02 right?
Post by EricTRocks » 21 Dec 2012, 00:00
Yeah that should work. Are you scaling each bone? This will lead to double scaling because each successive bone inherits its parents scaling.
Eric Thivierge
missingkey
Post by missingkey » 21 Dec 2012, 00:14
Naa I'm not scaling the joints, But I'm definitely still getting the double transforms. The Joint lengths measured after scaling the SRT cntrl are correct based on the measurement null chain - I double checked, the measurement/joint length's match, but the scale of the SRT still has effect on the joints. It must be something upstream in the hierarchy causing the joints to scale.
Post by EricTRocks » 21 Dec 2012, 00:54
Hmm. May want to link to a scene to see if anyone can take a look. I'm in the midst of moving over the next few days then there are holidays so I won't be able to help much unfortunately.
Eric Thivierge
missingkey
Post by missingkey » 21 Dec 2012, 01:01
Not to worry, You've been of great help.
I'll post a scene later tonight if anybody wants to pick it up and take a look at it for me. In the meantime, I'll try finding some of the free SI rigs, and dig around them for a bit.
missingkey
Post by missingkey » 21 Dec 2012, 04:33
Here's a quick scene file with something that's kinda working. a pose constraint further up the hierarchy seemed to be messing things up. Even with "scaling" turned off in the pose constraint(?), and hierarchical scaling turned off in the local transform scaling options of the joints.
In this scene, I've replaced the pose constraint with a point and orient, and all seems to be working, but had to add a scale constraint to the measure nulls. It seems a bit messy, and I'm really not sure of the best way to do this anymore. It seems every method has it's advantages and disadvantages.
everyframe
Post by everyframe » 30 Dec 2012, 01:08
replace the point and orient constraint with a pose constraint, and remove the scale constraint on the measure nulls. so the chain is being effected by the scale again on the "pelvis" cntrl. Then in ICE tree, instead of having to divide the joint length by the Global_SRT's scale. simply divide the new joint length (measure nulls), by the length of the joint when the global srt was scaled to 1, and divide the joint length by that.
here's your scene with the changes, and a properly scaling/stretching joint without too many changes to the existing ice tree.
missingkey
Post by missingkey » 31 Dec 2012, 19:01
Yes, that's exactly what i was looking for. Clever little trick for the scaling. It's so obvious now. Thanks man!
