piotrek255
Post
by piotrek255 » 12 Dec 2012, 15:23
Hi
What i am trying to do is smoke glass material effect, so that when object is thinner it is more transparent. I tried volume nodes but they are all dependant on camera angle/distance (even the BA_raylenght with "thickness" type set up)
Is it possible in softimage?
Post
by ActionArt » 12 Dec 2012, 15:37
Yes. Use the Architectural material. Not at my comp right now but I think it's called "absorption" or something like that.
piotrek255
Post
by piotrek255 » 12 Dec 2012, 23:27
there is a fallof option in the optimization panel of architectural material, but it just creates a fallof for refraction revealing the diffuse color, there is not much control either. I could not find absorption.
Post
by ActionArt » 13 Dec 2012, 03:08
Yes, sorry, it's called falloff. Isn't that what you wanted? You can set the end color to whatever you want (just check "use end color" and define a color. Turn your reflection to zero and index of refraction to 1 and you have neutral absorption so thinner areas will be more transparent.
I used it in this project and although it's subtle here it is an essential part of the look of the glass and beer:
https://www.si-community.com/forum/v ... r&start=10
You should be able to get pretty much exactly the effect in the example you've shown.
piotrek255
Post
by piotrek255 » 13 Dec 2012, 16:50
It works, great, but now i have another problem.... i cant get the refraction to show in alpha channel correctly, is is possible to make the refraction/transparency show correctly in alpha channel so i can composite glass/water model on any background i like?
I tried all of the shader nodes and none of them have an option to show refraction in alpha... maybe im doing something wrong
Post
by ActionArt » 13 Dec 2012, 16:59
Oh, can't help there. Maybe someone else?
This is a modified shader that has more options for output. Might want to check it out:
http://felixgeremus.com/?p=108
piotrek255
Post
by piotrek255 » 13 Dec 2012, 22:49
Ok, i remember i have something similar( if not the same) in my workplace, i will check that out.
Thanks for the help.
