render region different then rendering and preview?
thecook
Post by thecook » 10 Dec 2012, 10:37
i always check mark the "render region options" to use the current pass settings.
i never work with preview, only render regions.
now i realized the (first time ever), there are artifacts in my rendered pictures not visible the render regions.
issues seems to be connected with FG.
whats the story here?
gustavoeb
Skype: gustavoboehs
Re: render region different then rendering and preview?
Post by gustavoeb » 10 Dec 2012, 10:55
Using lens shaders?
Gustavo Eggert Boehs
thecook
Post by thecook » 10 Dec 2012, 10:58
gustavoeb wrote:Using lens shaders?
nope.
one architectural mat for glass and hdri env for lighting.
i mainly refer to the white artifacts.
they disappear when turn off FG.
Post by Hirazi Blue » 10 Dec 2012, 11:11
edit: superfluous remark: I somehow managed to overlook/ignore the very first line of your OP, sorry... :ymblushing:
thecook
Post by thecook » 10 Dec 2012, 11:21
hm, interesting property, never used it.
but since i always "Use Current Pass Options" in the Render Region Options,
all the copying becomes obsolete, since i set all the parameters directly in the MR pass property.
gustavoeb
Skype: gustavoboehs
Post by gustavoeb » 10 Dec 2012, 11:30
Might just be the fact that RR is not HDR then
thecook
Post by thecook » 10 Dec 2012, 12:38
gustavoeb wrote:Might just be the fact that RR is not HDR then
i consider that as a major information i was not aware of. thanx for this.
nevertheless, i switch now to "preview" and readjust my material settings.
Kzin
Post by Kzin » 10 Dec 2012, 12:58
a big problem i am having since the last projects. its really hard to work with high intensity lights and its reflections for example because final render looks different then render region. best is actually to use the preview render function because it renders correct intensitys.
thecook
Post by thecook » 10 Dec 2012, 13:09
Kzin wrote:a big problem i am having since the last projects. its really hard to work with high intensity lights and its reflections for example because final render looks different then render region. best is actually to use the preview render function because it renders correct intensitys.
exactly my problem and your solving.
