Simple self collide deformer
Simple Self CollideAuthor: Julien Silvestre
Julien's take on Paul Smith's Skin Collide concept. This deformer attempts to avoid self intersections by using ICE raycasting to push »inside« points to the outside.
Demo: selfCollide softimage ICE
local backup: SelfCollide_JS.xsicompound
jujut
Post by jujut » 09 Dec 2012, 12:01
Hello,
Here a simple self collide deformer:
For sure it's not perfect, but i think this compound can be usefull.
Critics and comments are welcome.
Re: Simple self collide deformer
Post by rray » 09 Dec 2012, 13:33
Thanks for sharing (video has disappeared). I tried recreating Pauls skin collision compound when he posted it but miserably failed b-(. Will try something that works directly on the envelope weights next.. if that's at all possible
jujut
Post by jujut » 09 Dec 2012, 13:45
sorry the video will be ok in few minutes, i've reupload it because i've some trouble to play it in non HD (i think bad resolution).
I see the paul smith video few time ago, he created a nice compound, i think his coumpound is better than mine, but i've decided to create my own from scratch in a way to learn more ICE.
Like to see the result of you process when it will be finish :)
Sil3
Post by Sil3 » 13 Dec 2012, 11:39
Thank you for sharing :)
iamVFX
Post by iamVFX » 13 Dec 2012, 15:39
Nice! Can't wait to test it, thank you, Silvestre!
druitre
Post by druitre » 13 Dec 2012, 17:23
Thanks a lot!
As a suggestion: is it also possible to combine this with volume preservation (via your fstretch-compound link or some other way)?
(The image is from an attempt of mine to do self-collision, being simple-minded it involves several shrinkwraps, collisiontargets and a fair amount of smooth operators, not flexible to set up at all)
jujut
Post by jujut » 15 Dec 2012, 03:51
thanks for the comments.
druitre : actually my fstretch like compound don't work like the self collide compound.The self compound work with raycast and the fstretch like compound don't use raycast at all but it's a good idea i will look and try to apply a bugle effect onto the self collide
I've made some modification on the self collide in a way to fix some penetration problem see attached picture
j3st3r
Post by j3st3r » 18 Mar 2013, 09:14
Did you upload the new compound? I still have serious issues even with a simple cylinder making the compound almost useless :(...
Szabolcs
jujut
Post by jujut » 20 Mar 2013, 10:55
Hello j3st3r, yes the new compound have been updated. What kind of problem do you have? Can you share you scene with this problem?
Falam
Post by Falam » 20 Mar 2013, 11:29
Does it work if the object is a child of a parent to collide with another object ? This compound falls into what I'm trying to do now.
jujut
Post by jujut » 20 Mar 2013, 12:03
the compound works only with one object on himself
j3st3r
Post by j3st3r » 25 Mar 2013, 09:02
I made a scene reproducing the issues
Falam
Post by Falam » 25 Mar 2013, 21:24
jujut wrote:Hello,
How did you make two objects collide ? I'm trying to do that.
jujut
Post by jujut » 26 Mar 2013, 19:15
j3st3r: i have look inside you scene, to remove this kind of problem you have to setup the parameter "distance" to 1 almost the time. But sometime for extra pose you can tweak the penetration by animated this parameter.
For exemple on you scene (see attach) to remove the issue i've key the parameter at 1 from key 1 to 65 and then to 2, and it's work fine. Like i say in the first post the compound is not perfect and need to be optimised.
Falam: on the video i use only one mesh on each example, if you need to do a collide between different object, you can do it easily in ice without this compound. This compound is use only for a self collide.
Falam
Post by Falam » 27 Mar 2013, 03:12
jujut wrote:j3st3r: i have look inside you scene, to remove this kind of problem you have to setup the parameter "distance" to 1 almost the time. But sometime for extra pose you can tweak the penetration by animated this parameter.
How would you go about this ?
jujut
Post by jujut » 27 Mar 2013, 12:55
hello,
i've attach to this message a quick exemple on how create deforming collision between two different mesh.
Hope it will help.
Bye
