dDo ?
Falam
dDo ?
Post by Falam » 09 Dec 2012, 02:04
Has anyone used dDo, how does it compare to xNormal ? I was considering buying it, it seems geared towards game modelling over high polygon modelling, or it doesn't matter ?
dwigfor
Re: dDo ?
Post by dwigfor » 09 Dec 2012, 06:56
I haven't tried it, but I thought I read that you use it conjunction with xnormal. First create your normal (ndo, xnormal, crazybump), and then use dDo for texturing.
dDo creates textures, not normal, AFAIK.
Falam
Re: dDo ?
Post by Falam » 09 Dec 2012, 07:23
dwigfor wrote:I haven't tried it, but I thought I read that you use it conjunction with xnormal. First create your normal (ndo, xnormal, crazybump), and then use dDo for texturing.
You can create your Normals in dDo. dDo progresses at textures ? xNormal and CrazyBump are from my standpoint good for normal maps, while dDo appears to do it all, I just don't get how they apply textures perfectly to parts of a mesh in dDo.
j3st3r
Re: dDo ?
Post by j3st3r » 10 Dec 2012, 13:14
dDo needs normal map, AO map, a base texture, a material ID map, and the geometry. Not all mandatory, but if you want good results the more information you feed, the better result it delivers. Beware, now it supports OBJs exported from Maya...
Falam
Re: dDo ?
Post by Falam » 10 Dec 2012, 13:27
j3st3r wrote:dDo needs normal map, AO map, a base texture, a material ID map, and the geometry. Not all mandatory, but if you want good results the more information you feed, the better result it delivers. Beware, now it supports OBJs exported from Maya...
Base Texture being something simple, I suppose ? I was doing a bit of reading on Material ID passes, can any clarify that all I need to do to create a Material ID pass is give objects, bright constant colors such as, red, green, blue etc ?
sonictk
Re: dDo ?
Post by sonictk » 12 Dec 2012, 03:50
You can create a base diffuse map with the colour scheme you want (literally just flat colours), provide a normal (or cavity map) and dDo will generate a diffuse map based on that information, with customizable controls (where the dirt appears, how much dirt you want, in cavities/height areas etc.) It's pretty rad and you should be trying out the beta and helping to report bugs. LIKE RIGHT NOW :D
Falam
Re: dDo ?
Post by Falam » 12 Dec 2012, 04:34
sonictk wrote:You can create a base diffuse map with the colour scheme you want (literally just flat colours), provide a normal (or cavity map) and dDo will generate a diffuse map based on that information, with customizable controls (where the dirt appears, how much dirt you want, in cavities/height areas etc.) It's pretty rad and you should be trying out the beta and helping to report bugs. LIKE RIGHT NOW :D
I haven't tried the demo, yet, although it is installed. It appears dDo is mainly good for creating dirt / scratches etc.
