how to generate plane geometry trails before object?
piotrek255
Post by piotrek255 » 28 Nov 2012, 17:30
Hi
I have a moving object moving along swirly path, is there a way to generate plane geometry trail? like in the movie tron, so i can add gradient on it or some other procedural texture.
TwinSnakes007
Re: how to generate plane geometry trails before object?
Post by TwinSnakes007 » 28 Nov 2012, 19:37
Lemme know what you figure out, because I need the same thing. But, I thought there was something already like this...a sprite that is always camera facing. Need to check the docs I think.
angelous4x
Post by angelous4x » 29 Nov 2012, 18:15
hey
there is a few ways that come to mind.
one is to use the emtopolizer buy eric mootz, you can leave a trail of merged messges.
or have a single particle with a a strand trailing it, and deform on a strand using. "PND_deform and strand" compound.
or just simply extrude on a path using Mx_loft or power extrude.
hope this helps
forton
Post by forton » 29 Nov 2012, 23:58
I want to do something similar, maybe this effect is something to start from:
Post by Daniel Brassard » 30 Nov 2012, 01:18
