Move Point - Moves One Point Not Two
Falam
Post by Falam » 28 Nov 2012, 16:04
When I am in the right or front view-port of an object, I must always tag the points I want to move, because the move point tool will only select one point instead of both points. Is there an option to move both points simultaneously with the move point tool ?
grahamef
Re: Move Point - Moves One Point Not Two
Post by grahamef » 28 Nov 2012, 22:21
Nope, you have to select multiple components first. The Tweak tool is meant for free-flowing, organic adjustments not precise modeling.
I'm not sure if this will be helpful, but one thing you can do is set Click Outside Manipulator to Select Tool in your Transform preferences. This lets you use the Transform tools instead of Tweak -- you still need to select first, but you don't need to use the keyboard shortcuts to switch tools.
Falam
Post by Falam » 28 Nov 2012, 22:29
grahamef wrote:Nope, you have to select multiple components first. The Tweak tool is meant for free-flowing, organic adjustments not precise modeling.
Thanks, I like it :)
