ICE MoGraph v1.1
nassosy
ICE MoGraph v1.1
Post by nassosy » 02 Oct 2009, 22:06
Version 1.1:
*Added more ICE compounds (Inherit Effector), improved existing
and changed the script. (Replace the existing compounds)
For XSI 7.01 and above.
Install (and replace) the ICE compounds by copying them to the appropriate locations.
Drag the included JS script "InPlaceInstance_with_ICE.js" onto a toolbar to make a button,
Select some geometric objects (not a group) and
press the previewsly created button, to make ICE instances in
a pointcloud object.
Then make a null "controller obj", add an Influence compound,
connect it to an Effector compound and just play with the settings.
Included are sample scenes.
This is a "just-for-fun" attempt to emulate something close to C4D MoGraph in ICE.
Hopefully people with add more compounds.
Use it at your own risk.
For the file
go to
http://area.autodesk.com/downloads/scri ... graph_v1_1
or here http://rapidshare.com/files/287918680/MoGraph_v1.1.rar
(I cannot upload it here because "The file is too big, maximum allowed size is 256 KiB.")
ace63
Re: ICE MoGraph v1.1
Post by ace63 » 04 Oct 2009, 19:23
Sounds cool, unfortunately I do not have time to play around with it at the moment, but I will be sure to have a look later.
