Softimage (standard user) load time ... slow
Falam
Post by Falam » 20 Nov 2012, 14:35
I'm having a problem with Softimage 2013 SP1, I can't say when it started, but it continues to happen, even after reinstalling. I run Softimage under a standard user, and the difference when I load under standard and when I load under administrator is noticeable. The administrator load time is significantly faster, but ignores all my preferences, project list etc. I ran runonce.bat, that didn't solve the issue either, can this be fixed without re-installing ?
Re: Softimage (standard user) load time ... slow
Post by xsisupport » 20 Nov 2012, 17:21
Falam wrote:I'm having a problem with Softimage 2013 SP1, I can't say when it started, but it continues to happen, even after reinstalling. I run Softimage under a standard user, and the difference when I load under standard and when I load under administrator is noticeable. The administrator load time is significantly faster, but ignores all my preferences, project list etc. I ran runonce.bat, that didn't solve the issue either, can this be fixed without re-installing ?
Could be your preferences etc that are slowing things down.
Rename the User folder for your Standard user account and see.
// Steve Blair
Falam
Post by Falam » 21 Nov 2012, 03:36
It is safe to assume you mean the Softimage 2013 SP1 folder within the User folder, not the entire User Folder ? :)
Post by xsisupport » 21 Nov 2012, 09:22
Sure :)
To rephrase: rename the Softimage folder in the User location.
// Steve Blair
Falam
Post by Falam » 23 Nov 2012, 12:53
Sure :)
That didn't work, Softimage continue to load extremely slow. :(
Post by origin » 23 Nov 2012, 23:28
windows 8?
Falam
Post by Falam » 24 Nov 2012, 00:09
origin wrote:windows 8?
Windows7 x64
Falam
Post by Falam » 28 Nov 2012, 00:27
Sure :)
Any other suggestions ?
Post by xsisupport » 28 Nov 2012, 10:46
If it was my machine, I'd use Process Monitor to see what's going on.
Also, try creating a new standard user account. Is that slow or fast?
edit: And oh...have you restarted the machine recently?
// Steve Blair
Falam
Post by Falam » 28 Nov 2012, 14:03
xsisupport wrote:If it was my machine, I'd use Process Monitor to see what's going on.
I've restarted the machine numerous times, recently, for updates etc. The machine is up to date. I'll try process monitor, post any findings.
Falam
Post by Falam » 28 Nov 2012, 17:59
Can I send you the process monitor log file, maybe you can debug it to find the problem ?
Post by xsisupport » 28 Nov 2012, 18:41
I'll take a quick look, because I'm the curious type.
I'll need the PML file.
// Steve Blair
Falam
Post by Falam » 28 Nov 2012, 20:35
I ran process monitor then I run Softimage from a command prompt, and process monitor shows me nothing. I must have restarted process monitor a dozen times, scratching my head as to why it's not logging anything. It is just a blank canvas, arghh.
Post by xsisupport » 28 Nov 2012, 21:07
CTRL+E to capture events?
Check that there are no stray ProcMon processes running.
// Steve Blair
Falam
Post by Falam » 28 Nov 2012, 21:58
There was a stray ProMon running, ending that task didn't start up, process monitor, it remains empty after clearing it, setting a filter, running Softimage from a CMD prompt, running Softimage from the Icon <sigh>.
Post by xsisupport » 29 Nov 2012, 13:57
Try running Process Monitor with a different user account: your Admin account, or perhaps a new Standard user account.
It seems rather strange that Process Monitor doesn't work.
// Steve Blair
