Help - Problems with display in the viewport
mat946
Post by mat946 » 14 Nov 2012, 11:04
Hello.
I'm new in softimage and I'm learning this software.
I have problem with shaded view. I'm attach picture with this.
My hardware:
2 x Intel Xeon CPU X5660 2,8 GHz
Ram: 48 GB
NVIDIA Quadro 5000
edited by gustavoeb: Title was very generic, now it is more descriptive of the actual content in the thread :)
gustavoeb
Skype: gustavoboehs
Re: Help ;]
Post by gustavoeb » 14 Nov 2012, 12:03
And the problem is? I mean, I see it is not perfect, but are you talking about the missing pieces or the noise patterns that happend on some corerns of your geometry?
It is hard to say without more details... BUT it does look like you brought something from other package, and that this package uses a bigger scale then SI does. If so your geometry might be not fitting in the clipping plane of the camera. You should adjust it to your scene scale in your camera properties, and everything will be fine.
http://download.autodesk.com/global/doc ... ty1503.htm
Gustavo Eggert Boehs
mat946
Re: Help ;]
Post by mat946 » 14 Nov 2012, 12:17
Thank you for reply, I will check this, but if i render my model is fine.
gustavoeb
Skype: gustavoboehs
Re: Help ;]
Post by gustavoeb » 14 Nov 2012, 12:20
I see, it is probably the clipping plane then, as it only affects the openGL viewport...
mat946
Re: Help ;]
Post by mat946 » 14 Nov 2012, 12:58
It's works. Thanks a lot ;)
