Alpha channel in OpenEXR not working during render time
nver009
Post by nver009 » 12 Nov 2012, 12:36
I have problems with rendering OpenEXR RGBA Float. The problem is that the alpha channel will not come through (Which I checked with Nuke). In the viewport renderer using 'Q' + Drag it was definitely clear that there was an alpha channel when I flipped it to Alpha. The material I used is mia_material_x (Glass shader) plugging only the 'reflection_result' into Surface of the Shading Group which recieves reflections from HDRI. The only light source is a HDRI.
What would the problem be?
Kzin
Re: Alpha channel in OpenEXR not working during render time
Post by Kzin » 12 Nov 2012, 13:20
nver009 wrote:Hi,
you have to check the alpha option in mia mat:
"transparency uses background alpha channel"; its under additionell options.
nver009
Post by nver009 » 12 Nov 2012, 14:29
Thank you for the reply!
However I cannot find that switch to turn on "transparency uses background alpha channel" in the mia_material_x. Can you please show me an example?
Thank you!
Post by ActionArt » 12 Nov 2012, 15:00
Sorry to ask the obvious, but are you saving the exr as RGBA, not RGB?
Post by Hirazi Blue » 12 Nov 2012, 15:30
nver009 wrote:Thank you for the reply!
Thank you!
With the different naming convention between the Architectural Material and the mia_material I believe you'd have to look for the "propagate_alpha" parameter...
krazeban
Post by krazeban » 12 Nov 2012, 22:21
Hi, I'm working with nver and replying for the group.
Yes it is set to RGBA. I have tried both TIFF/RGBA/Float, also OpenEXR/RGBA/Float. Both yielding the same result.
I have also tried the 'Propogate Alpha' switch located in the mia_material_x but with no success. Could it possibly be a problem with the HDRI?
The way I created it is by Edit->Current Pass->Pass Shaders->Environment. I hook up the HDRI to Environment and turn the 'Background' attribute to 0 to get only the Reflections which is what we require.
This is some WIP videos to what we're doing which is simply a glass shader using mia_material_x reflecting a HDRI. They were batch rendered but the problem is that they have no proper alpha that could be worked with in Comp.
https://vimeo.com/53292274
https://vimeo.com/52989925
Thank you for your help :)
Ba An
