Fake dispersion within the object
iamVFX
Post by iamVFX » 02 Nov 2012, 11:17
Has anyone know any way to fake dispersion for a transparent refractive object on a compositing stage? Any links would be helpful!
Letterbox
Re: Fake dispersion within the object
Post by Letterbox » 02 Nov 2012, 20:36
like this?
or this...
grail.cs.washington.edu/theses/ChuangPhd.pdf
iamVFX
Post by iamVFX » 03 Nov 2012, 09:50
No, not really make the refraction, but do tricks (if they exist at all) to make dispersion on an already refractive object with use of different passes, maybe. For example it could be based on a shift of different colored reflection/refraction passes with use of uv pass, or something like that... Oh well :D
Kzin
Post by Kzin » 05 Nov 2012, 13:17
http://www.mentis.ca/design/graphics/dispersion/
found this some time ago. but because you have to render the object 3 times i would go with the mib_glossi_refraction to render it directly.
iamVFX
Post by iamVFX » 05 Nov 2012, 14:59
Kzin wrote:http://www.mentis.ca/design/graphics/dispersion/
found this some time ago. but because you have to render the m object 3 times wi would go with the mib_glossi_refraction to render it directly.
Exactly what I was looking for! Thank you, Kzin :)
